Element ID in schedules c# revit api
alena.karle
alena.karle
Hello Forum,
How to get Element ID in schedules with c# and revit API? similar to this video with Dynamo  - https://youtu.be/U-tVoCYilxo - but with c# and revit api.
here is my try:
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Nice3point.Revit.Toolkit.External;
using Ecoworx.Core.Elements;
namespace Ecoworx
[Transaction(TransactionMode.Manual)]
public class CreateScheduleCommandHandler : ExternalEventHandler
public override void Execute(UIApplication uiapp)
UIDocument uidoc = uiapp.ActiveUIDocument;
Application app = uiapp.Application;
Document doc = uidoc.Document;
CreateSchedule(uiapp);
public static void CreateSchedule(UIApplication uiapp)
using (Transaction t = new Transaction(doc, "Create single-category"))
t.Start();
// Create schedule
ViewSchedule vs = ViewSchedule.CreateSchedule(doc, new ElementId(BuiltInCategory.OST_Windows));
ElementId someId = new ElementId(BuiltInCategory.OST_Windows);
BuiltInParameter bip = (BuiltInParameter)(someId.IntegerValue);
doc.Regenerate();
// Add fields to the schedule
AddRegularFieldToSchedule(vs, new ElementId(BuiltInParameter.CASEWORK_WIDTH));
AddRegularFieldToSchedule(vs, new ElementId(BuiltInParameter.CASEWORK_HEIGHT));
AddRegularFieldToSchedule(vs, new ElementId(bip));
t.Commit();
public static void AddRegularFieldToSchedule(ViewSchedule schedule, ElementId paramId)
ScheduleDefinition definition = schedule.Definition;
// Find a matching SchedulableField
SchedulableField schedulableField =
definition.GetSchedulableFields().FirstOrDefault(sf => sf.ParameterId == paramId);
if (schedulableField != null)
// Add the found field
definition.AddField(schedulableField);
architect.bim
Hi!
Similar to this video, you need to create a FilteredElementCollector for the required category, select all its instances and for each element get its Id and assign a value to some of its instance parameters (for example, to "Comments" parameter). Then you can add this parameter as a schedule field and retrieve the ElementId through the schedule. Here is an example in python, I'm sure you can adapt it to C#:
elements = FilteredElementCollector(doc) \
    .OfCategory(DB.BuiltInCategory.OST_Windows) \
    .WhereElementIsNotElementType()
with DB.Transaction(doc, 'Set "Comments" Parameter Value for windows') as t:
    t.Start()
    for element in elements:
        element.Parameter[DB.BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS].Set(str(element.Id))
    t.Commit()
Maxim Stepannikov | Architect, BIM Manager, Instructor
