Edit in-place family material via Revit api
Greetings Revit Community
I would like to ask for help with my plug-in function, I will head straight into the issue
The goal:
1. get in-place Family instance
2. get the generic forms and iterate them to change the material of them, I only want simple change, different material with different color
The issue:
I could not edit the in-place family because of the API limit on editing this instance
I searched all around to find a way to change the material of the in-place family but no hope
from my search I found on this post
https://forums.autodesk.com/t5/revit-api-forum/family-in-place-api/m-p/7082088/highlight/true#M22819
this is from 2019, while I understand it's not a priority for the development team, I would like to ask to give it more
priority for this case, as many developers are facing the same issue from my search but different goals
if anyone knows a way to change in-place family instance generic forms material, I will appreciate it
thanks in advance for any help
jeremy_tammik
To raise the priority of a new feature request, please ensure that it is listed in the Revit Idea Station.
Whenever you require new or enhanced Revit or Revit API functionality, the Revit Idea Station is the place to go.
Please search there for a corresponding wish list entry for the suggested functionality and add your comments to it, or create a new one, if none already exists:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Tag it as an API wish:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302/tab/most-recent/label-name/api
Ensuring that a wish gets as many votes as possible helps underline its importance to you and the rest of the developer community.
The Revit Idea Station is currently one of the main driving input forces for Revit API enhancements.
The Revit development team look there. Your comment here in the discussion forum might be overlooked.
Thank you!
That said, you may be able to programmatically modify the material of an individual face of some element geometry regardless of what kind of element it lives on. Some suggestions on controlling element colour and material are listed here:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.24
A recent discussion here in the forum explains how to Use a different material on each face of a tessellated shape:
https://forums.autodesk.com/t5/revit-api-forum/using-different-material-on-each-face-of-a-tessellate...
Maybe that will provide a hint as well.
Hey
 //creating new material
                ElementId mt = Material.Create(doc, RandomString(10));
                Material material = doc.GetElement(mt) as Material;
                Color myColor = new Color(255, 192, 203);
                material.Color = myColor;
                FamilyInstance FI = elem as FamilyInstance;
                Family f = FI.Symbol.Family;
                ISet<ElementId> familySet = f.GetFamilySymbolIds();
                foreach (ElementId id in familySet)
                    Element el = doc.GetElement(id);
                    foreach(ElementId ids in el.GetMaterialIds(true))
                      //can't figure out next step here
EATREVITPOOPCAD
I think I came across a post that has a function for what you are looking to do
https://forums.autodesk.com/t5/revit-api-forum/set-material-parameter-value/td-p/8227041
 public void SetMaterial(FamilySymbol fs)
               IList<Parameter> pars = fs.GetOrderedParameters();
                foreach (Parameter p in pars)
                    if (p.Definition.Name == "Material")
                        Material m = GetMaterial(doc, "Glass");
                        if (m!= null)
                            fs.Category.Material = m;
                            p.Set(m.Id);
The definition of insanity is doing the same thing over and over again and expecting different results
