Edit closed views
Edit closed views
Edit closed views
Im busy to change the location and shape of Detail lines in Section view. I have a problem if the view is close because I cant edit the detail line. Just it works if the view is open.
how can i solve this problem?
Hossam
FAIR59
My test (Revit 2016) works fine.
I suspect you use doc.ActiveView somewhere in your code.
if so you'd have to use the Ownerview of the detailLine.
my testcode:
            DetailCurve dc = doc.GetElement(new ElementId(2043213)) as DetailCurve;
                using (Transaction t = new Transaction(doc, "offset detailLine"))
                    t.Start();
                    View view = doc.GetElement(dc.OwnerViewId) as View;
                    Plane pl = dc.SketchPlane.GetPlane();
                    dc.SetGeometryCurve( Line.CreateBound(pl.Origin,pl.Origin.Add(pl.XVec)),true);
                    t.Commit();
