Easy Programming Exercise
Well, easy for someone other than me.  I am completely new to the Revit API and would like to create a script that deletes all of the views and sheets from a file.  Any suggestions?
Thanks.
- Alex
I'm learning the API so I figured I would take a crack at it.
I don't know your experience level with programming in general or even what language your using but the code below worked for me.  If it's over your head, I also attached the finished product.  To use the addin, place the addin in your Revit 2011 Addin folder (see below) and the Deleter.dll at C:\  Then next time your in Revit you will have this command available under the 'Addins' ribbon tab then under 'External Commands'
 Addin Locations:
XP - C:\Documents and Settings\All Users\Application Data\Autodesk\Revit\Addins\2011
Vista/7 - C:\ProgramData\Autodesk\Revit\Addins\2011
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using System.Collections;
namespace Deleter
    [Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)]
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Automatic)]
    public class SheetsAndViews : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            // Warn the user about deleting all views and sheets
            TaskDialogResult result = TaskDialog.Show("Delete All?", "This command will delete all sheets and views in the current project. \r\n\r\nAre you sure you want to continue?",
                TaskDialogCommonButtons.Yes | TaskDialogCommonButtons.No, TaskDialogResult.No);
            //End the command if no was clicked
             if(result == TaskDialogResult.No)
                 return Result.Succeeded;
            // Get the active UIDoc
            UIDocument uiDoc = commandData.Application.ActiveUIDocument;
            try
                DeleteSheetsAndViews(uiDoc);
                TaskDialog.Show("Success", "All views deleted successfully.");
            catch (Exception Ex)
                TaskDialog.Show("Error", "An error occurred.\r\n\r\n" + Ex.Message);
                return Result.Failed;
        private void DeleteSheetsAndViews(UIDocument uiDoc)
            // Used to store the ElementIds to delete
            ArrayList list = new ArrayList();
            // Get all of the Views in the current drawing
            FilteredElementCollector collector = new FilteredElementCollector(uiDoc.Document);
            FilteredElementIterator iterator = collector.OfClass(typeof(View)).GetElementIterator();
            iterator.Reset();
            // Iterate all of the views and collect their ElementIds
            while (iterator.MoveNext())
                View v = iterator.Current as View;
                if (v.ViewName != uiDoc.Document.ActiveView.ViewName)
                    list.Add(v.Id);
            // Delete all of the collected ids
            foreach (ElementId id in list)
                uiDoc.Document.Delete(id);
Thank you so much; I had pretty much given up on figuring this out.
I'll give it a shot.
- Alex
Sferra, I like the warning box at the beginning. The formatting on it is straight forward, and simple enough that users will actually read it. Thanks for sharing.
