dynamo script auto join
Geoffrey.Denie
Geoffrey.Denie
I wrote a simple dynamo script to join all my foundation elements together. I was able to filter all the elements that I would like to join. However when I run the script only the first two elements of the list are joined (marked in blue on the screenshot). Is there a way to automate this process for all the other elements in the list?
Thanks and best regards
Geoffrey
sstewartPHEFA
 You might have better luck posting on the Dynamo Forums if you haven't.
Have you tried changing the lacing on that final node?
Geoffrey.Denie
Yes, that was the issue. I had to change the lacing to cross product. thank you!
