DWG Export Error
DWG Export Error
duc_phan4PZR5
DWG Export Error
duc_phan4PZR5
Dear to all,
This is real revit, pullbox is on board
but when i export to dwg it shows correct and incorrect (pullbox not on board), i tried many ways like changing type,.. but still not working
reproduce bug
(view in My Videos)
Link model:
10012024_ver17.rvt
jeremy_tammik
Afaict from your description, this is a pure DWG export problem. Is the behaviour identical when you drive it manually through the end user interface? If it differs, i.e., works correctly through the UI and causes problems via the API, please state so and provide a complete minimal reproducible case for both contexts that we can pass on to the development team for analysis:
If the UI and API behaviour is identical, as I would expect, then it is not an API issue. In that case, please raise it in the larger and more generic architectural forum for the product support team to take a look. Maybe they have some suggestions on optimal workflows and best practices that we are not aware of here in the API-specific forum:
duc_phan4PZR5
thanks to jeremy, the UI and API behaviour is identical, so i will raise to the product support team.
