Duplicating PlanView and dependent views
HI guys,
I posted this same issue on Augi but im not sure they have the same talent as you guys 🙂
I am pretty new to programming and the revit API but i under stand the program and its user unterface very well.
What i am trying to make is a add-in that automates a process of creating views for loadbearing under views, the idea is that the addin create a duplicate of a selected view and applies a view template for the correct view settings then adds it to the selected sheet.
This is the process i want to follow:
a. User to select API tool in add-ins tab in revit,
b. Prompt user to select view <Host View>,
//Duplicate view
//rename view to “<Host View> Under & Over”
//apply view template “Profile Under & Over”
//move view type to “Profile Under & Over” or duplicate view type and rename to “Profile Under & Over”
//(if Host View has dependent views apply sequence b1 otherwise proceed to sequence c)
b1.
//Apply dependent views from Host View
//rename dependent views “<Host View> Under & Over - Part <1>”
c. Prompt user to select “sheet” or “create new sheet” in dialog,
if selected “sheet”
//move “<Host View> Under & Over” or if dependent “<Host View> Under & Over - Part <1>”centre to centre on sheet
if selected “create new sheet”
//create new sheet
//rename sheet to “<Host View>” or if dependent “<Host View> - Sheet <1>
Now there are lots of steps between all the listed steps that im still learning to get the end resault.
This is the start of what i have done with regards to the code to select the view:
using System;
using System.Collections.Generic;
using System.Linq;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
[TransactionAttribute(TransactionMode.Manual)]
[RegenerationAttribute(RegenerationOption.Manual)]
public class Lab1PlaceGroup : IExternalCommand
  public Result Execute(
    ExternalCommandData commandData,
    ref string message,
    ElementSet elements)
    //Get application and document objects
    UIApplication uiApp = commandData.Application;
    Document doc = uiApp.ActiveUIDocument.Document;
    //Define a Reference object to accept the pick result.
    Reference pickedRef = null;
    //Pick a view
    Selection sel = uiApp.ActiveUIDocument.Selection;
    pickedRef = sel.PickObject(ObjectType.Element, "Please select a view");
    Element elem = pickedRef.Element;
    ViewPlan profileplan = elem as ViewPlan;
Now i am stuck here.. What i want to do next is duplicate the view but i am not sure how to apply duplicate () and how to check / apply that to dependent views, do i do this in a new class or can i do it in the current class?
Any help would be much appreciated
Thanks heaps
Dave
Hi Dave,
I have simple solution that I use to duplicate the active view, hope this helps.
  public void DuplicarVista()
            UIDocument uidoc = this.ActiveUIDocument;
            Document doc = uidoc.Document;
            View pickedRef = null;
            pickedRef= uidoc.ActiveView;
            int nduplicates = 5;
            using (Transaction t = new Transaction(doc,"Set workset"))
                       t.Start();
                    for (int i = 1; i < nduplicates; i++) {
                        //Check if view can be duplicated
                           if (pickedRef.CanViewBeDuplicated(ViewDuplicateOption.AsDependent))
                               pickedRef.Duplicate(ViewDuplicateOption.AsDependent);
                       t.Commit();
Andrei Bejenaru
