Following along with this great sample found at revitapidocs (pasted below), I've changed out the "AsDependent" bits to "WithDetailing", the view Duplicates but does so without detailing. Strangely, line 7 in the code below returns -1 even though a new view is created and appears in the Revit UI. This leaves dependentView = null, so line 9 fails the check.
I also noticed the same behavior in pyRevit's Duplicate Selected Views tool and reported the bug on their github page.
I've checked this in Revit 2022 & 2023.
Here is the sample code. Again, I have changed "AsDependent" to "WithDetailing", otherwise my code is the same as below. The calling function sets up a Transaction. The Transaction succeeds and appears in the UI undo history:
public View CreateDependentCopy(View view)
View dependentView = null;
ElementId newViewId = ElementId.InvalidElementId;
if (view.CanViewBeDuplicated(ViewDuplicateOption.AsDependent))
newViewId = view.Duplicate(ViewDuplicateOption.AsDependent);
dependentView = view.Document.GetElement(newViewId) as View;
if (null != dependentView)
if (dependentView.GetPrimaryViewId() == view.Id)
TaskDialog.Show("Dependent View", "Dependent view created successfully!");
return dependentView;
Solved by stewartcartmell. Go to Solution.
Hi @stewartcartmell ,
I tested the sample code at my end and everything is working fine on my end.
Could you please provide me the below details to reproduce the issue?
1)A simple non-confidential Revit file to reproduce the issue
2)Screenshots of expected result and observed result
3)A simple non-confidential sample code
4)Revit version details.
Hi Naveen,
So sorry, the strangest thing happened. When I started my PC this morning the duplication script worked without issue. I had restarted Revit, and then later the PC yesterday to see if that would help, and when it didn't I wrote the post. I must have been mistaken. Thanks for taking the time to check this for me, I did not mean to waste your time. In the future I'll give the PC an overnight rest to see if that helps again 😉
