DUCT
DUCT
DUCT
I want to develop a new plugin for Revit with "visual studio" for duct drawing. Drawing from the plugin I created with a command like "start drawing"
I want to continue as much as I want. then, I want to make a standard size split that I have determined duct drawn. Can you help me for the code (C#) ?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
This below link will help you to create a duct
There are 3 methods to create a duct in Revit using Revit API
https://www.revitapidocs.com/2017/bd4f213f-0ff0-0b43-1c3c-4ae23c9061e7.htm
Also, check this below link
https://thebuildingcoder.typepad.com/blog/2012/03/split-a-duct-or-pipe.html
If this doesn't help, could you please explain clearly what you are trying to do?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
aliriza.yilmaz
go to taksim, you can find your answer
Thank you Mr.ali. How can i go to Takşim.
aliriza.yilmaz
 You should listen that guy and get to taksim easily my friend.
https://www.youtube.com/watch?v=-cgUTDQwsgI
