Draw the dimension for duct
ttnhan1
ttnhan1
Line line = Line.CreateBound(topleft, botleft);
DetailLine detailLine = doc.Create.NewDetailCurve(doc.ActiveView, line) as DetailLine;
Reference ref = new Reference(detailLine);
arrRef.Append(ref);
I am making an API to draw the dimensions for elements automatically. I have some issue with the duct's dimension.
I created the dimension with this method:
doc.Create.NewDimension(doc.ActiveView, dimensionLine, refArr);
and I prepared the referenceArray with the duct by creating a new reference from the duct
Reference ductRef = new Reference(duct);
refArr.Append(ductRef);
This's what I got:
The witness line of the dimension refers to the center of the duct. But I want to create the dimension like this:
I want the witness line to refer to two sides of the duct. Is there a way to do that?
I researched, and there is a suggestion about creating a line that is parallel with the duct sides and getting references from that line.
arrRef.Append(ref);
 However, I don't really want to create another line to the model like this. Is there a way to get the reference directly from two sides of the duct?
jeremy_tammik
Have you explored all the possible references provided by the duct? I don't know whether RevitLookup provides access to them all, but it is worth a try, at least. My last foray into dimensioning was for arcs and yielded this result:
So, lots of room for experimentation.
I understand that you wish to avoid creating extra elements.
If worst came to worst, you could do the following:
  • Determine the points for the dimension
  • Create a line segment between them
  • Dimension the line segment
  • Delete the line segment
All of the above could be wrapped into a DMU dynamic model updater that reacts to geometry changes of the duct, similar to the DynamicModelUpdate Revit SDK sample.
ttnhan1
Hi @jeremy_tammik,
Thank you for your suggestion!
I discovered that we could use RevitLookup to access the duct's edge, so I found a way to do that by code.
I followed this to access the edges. https://www.revitapidocs.com/2020.1/7f25fe6f-a427-7ac3-6753-2dec37fb058c.htm
This is my code:
BoundingBoxXYZ ductBB = duct.get_BoundingBox(doc.ActiveView);
// Get geometry element of the selected element
Autodesk.Revit.DB.Options geoOptions = app.Create.NewGeometryOptions();
geoOptions.ComputeReferences = true;
Autodesk.Revit.DB.GeometryElement geoElement = duct.get_Geometry(geoOptions);
FaceArray faces = ((Solid)geoElement.First()).Faces;
foreach (PlanarFace face in faces)
    XYZ origin = face.Origin;
    if (Math.Round(origin.Z,8)  == Math.Round(ductBB.Max.Z, 8))
        foreach (Edge edge in face.EdgeLoops.get_Item(0))
           //get the reference by edge.GetEndPointReference(0))
        break;
This is the result
The important thing in this is the geometry option. We should set it like this:
to get the reference for dimension. (https://adndevblog.typepad.com/aec/2013/06/facesedges-returned-from-elementgeometry-have-no-referenc...)
Thank you for being so helpful!
jeremy_tammik
Congratulations on the very good solution and thank you for your appreciation and sharing the results!
