Draw a Property line
Is any one have an idea to draw property lines programatically for Revit 2019 ??
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
A wish list item was already raised for it in the past:CF-1612 [Creating and editing Property Line using API].
https://forums.autodesk.com/t5/revit-api-forum/create-property-line-programmatically/td-p/5600736
https://forums.autodesk.com/t5/revit-api-forum/how-to-create-property-line-by-using-api/m-p/7907679
you can also achieve this task using Revit postable command
 RevitCommandId id = RevitCommandId.LookupPostableCommandId(PostableCommand.PropertyLine);
 uiapplication.PostCommand(id);
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thanks Naveen.
I tried out post command its working.
But could you please tell me ,how to pass co-ordinates to Post Command ????
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Unfortunately, I am sorry to say that the PostCommand functionality does not accept passing parameters to the PostCommand() method. The method will just launch the built-in/add-in Revit command as it is, including all its user interaction.
It does not include any possibility to supply any additional input arguments or programmatically define the selection, it will prompt the user for the standard manual interaction, just like Revit normally would.
You can refer this blog for more information
https://thebuildingcoder.typepad.com/blog/2013/10/programmatic-custom-add-in-external-command-launch.html
Naveen Kumar T
