door's height, width parameters are not showing in Revit LookUp plugin (Revit beginner)
please find the attached images.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
The door's width and height parameters are type parameters not instance parameters.
In your revit lookup, You are accessing the instance parameters of the door.
Try to access the type parameters of the door element type.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thank you Naveen for your valuable reply
DOLAPO836
Hi @naveen.kumar.t,
please how do I access the Revit type parameter of the door from the Revit lookup?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @DOLAPO836 ,
Could you please take a look at this below link?
https://forums.autodesk.com/t5/revit-api-forum/how-to-get-type-parameters-of-beam/td-p/5925936
Naveen Kumar T
DOLAPO836
Thank you very much
