There is so many tutorial how to add parameter or how to go to familymanager....
But I need so simple value of width of family door...
Don't understand the tree ...
I have now this ...its good way?
Family family = q.Symbol.Family; Document familyDoc = doc.EditFamily(family); FamilyManager familymanager = familyDoc.FamilyManager; IList<FamilyParameter> familyPar =familymanager.GetParameters();
Thx...
Solved by matthew_taylor. Go to Solution.
Hi @sonicer,
Refer here for help on getting started:
The most important thing to do is install RevitLookup - it will help you navigate the database. A quick google will help you find it.
Your query will appear simple when you use it.
Dim widthInFeet as double= _
doorFamilyInstance.symbol.Parameter(BuiltinParameter.Door_Width).AsDouble
estimado,
mi duda es cuando tengo un parametro compartido dentro de la familia. como en la imagen.
