Doesn't get the minimal bounding box from the solid of the structural column
yuvdal
yuvdal
I am trying to get the bounding box from the solid of structural column but unfortunately, I don't get the minimal one.
In order to demonstrate it, I modeled in-place the following structural column:
Then I tried to run the following function that gets the bounding boxes from all the solids and merges them. In order to show the result, I display the bounding box.
            // Application context
            var uidoc = commandData.Application.ActiveUIDocument;
            var doc = uidoc.Document;
            var selectionReference = uidoc.Selection.PickObject(ObjectType.Element);
            var selectionElement = doc.GetElement(selectionReference);
            //Override the options to use Fine detail level
            List<BoundingBoxXYZ> solidsBoundingBoxes = new List<BoundingBoxXYZ>();
            Options options = new Options { ComputeReferences = true, DetailLevel = ViewDetailLevel.Fine };
            GeometryElement geometryElement = selectionElement.get_Geometry(options);
            foreach (GeometryObject geomObject in geometryElement)
                // You can obtain wall solid with method in the top but some other elements need this type conversion
                if (geomObject is GeometryInstance geomInst)
                    // Instance geometry is obtained so that the intersection works as
                    // expected without requiring transformation
                    GeometryElement instElem = geomInst.GetInstanceGeometry();
                    foreach (GeometryObject instObj in instElem)
                        if (instObj is Solid innerSolid)
                            if (innerSolid.Volume > 0)
                                BoundingBoxXYZ boundingBox = new BoundingBoxXYZ();
                                XYZ bBoxOrigin = innerSolid.GetBoundingBox().Transform.Origin;
                                boundingBox.Max = innerSolid.GetBoundingBox().Max + bBoxOrigin;
                                boundingBox.Min = innerSolid.GetBoundingBox().Min + bBoxOrigin;
                                solidsBoundingBoxes.Add(boundingBox);
            //Get the surrounding bounding boxes that were collected by finding the lowest min point and highest max point
            BoundingBoxXYZ surroundingBoundingBox = GetBoundingBoxUtils.GetSurroundingBoundingBox(solidsBoundingBoxes);
            // Display the Merged Bounding Box from the Solids
            var elem = DisplayUtils.DisplayBoundingBox(surroundingBoundingBox);
The problem is that the bounding box that I get from the solids is not the minimal one. There is an offset of 1/16" from each side of the structural column.
I'm trying to figure out what I'm missing, because for comparison when I run a similar graph in Dynamo, it shows me the correct bounding box from the solids.
I would be glad if someone could help me understand what the difference is between what I do in the code and the Dynamo graph.
Thanks a lot,
Yuval
jeremy_tammik
Dear Yuval,
You seem to be repeating the same question I already answered in this previous recent thread:
Remember: a bounding box is a bounding box. There is no guarantee that a bounding box is minimal. Never.
The main purpose of a bounding box is speed, not accuracy, and definitely not to be minimal.
Since you can never assume that a bounding box is minimal, and if this is causing an issue with your code, I would recommend checking whether is is erroneously making this assumption. If it is, it might be safer to fix it.
If your application requires a minimal bounding box, the safest way to obtain it is to query the element geometry for all its vertices and create a convex hull or truly minimal bounding box from those.
I described an approach to retrieve the element geometry vertices in this other recent discussion:
I would create a list of unique values while iterating over all the face vertices. The Building Coder demonstrates several variations of this with methods such as GetVertices in CmdNestedInstanceGeo.cs:
I hope this clarifies.
Best regards,
Jeremy
