Does Revit2015 Platform API Developers Guidelines exists?
OR_AND_NO
OR_AND_NO
To coding for revit2014 i used Revit2014 Platform API Developers Guidelines.
A few weeks ago I upgrade to revit2015 and discover that some examples from pointed above guidelines don’t work and parameters of some methods were changed.
For example (Code Region 29-14: Adjusting the analytical model in relation to another element) don't work in revit2015 exeption - “An internal error has occurred.”
      public Result Execute(Autodesk.Revit.UI.ExternalCommandData commandData,ref string message,ElementSet elements)
            m_application = commandData.Application;
            m_document = m_application.ActiveUIDocument;
              try
               Selection sel = m_document.Selection;
               Reference refAnalytical = sel.PickObject(ObjectType.Element,"Please Pick the source analytical line to adjust to");
               Element el = m_document.Document.GetElement(refAnalytical);
               AnalyticalModel aModel = el.GetAnalyticalModel ();
// in original example wasAnalyticalModel aModel = doc.GetElement(refAnalytical) as AnalyticalModel;
               Curve aCurve = aModel.GetCurve();
               // Get the reference of the start point
               AnalyticalModelSelector aSelector =new AnalyticalModelSelector(aCurve);
                aSelector.CurveSelector =AnalyticalCurveSelector.StartPoint;
               Reference refSource = aModel.GetReference(aSelector);
                // Pick the source analytical line to be adjusted
               Reference refAnalytical2 = sel.PickObject(ObjectType.Element,"Please pick the source analytical line to be adjusted");
                el = m_document.Document.GetElement(refAnalytical2);
               AnalyticalModel aModel2 = el.GetAnalyticalModel();
// in original example wasAnalyticalModel aModel2 = doc.GetElement(refAnalytical2) as AnalyticalModel;
               Curve aCurve2 = aModel2.GetCurve();
                AnalyticalModelSelector aSelector2 =new AnalyticalModelSelector(aCurve2);
          //     aSelector2.CurveSelector = AnalyticalCurveSelector.StartPoint;
               // Can be adjusted to the middle of the line if WholeCurve is used
                aSelector2.CurveSelector =AnalyticalCurveSelector.WholeCurve;
               Reference refTarget = aModel2.GetReference(aSelector2);
               // Adjust the analytical line
                bool res=aModel.ManuallyAdjust(refSource, refTarget);
//in original example aModel.ManuallyAdjust(refSource, refTarget, true);
               return Result.Succeeded;
           catch (Exceptions.OperationCanceledException)
               // Selection Cancelled.
               return Result.Cancelled;
           catch (Exception ex)
               // If any error, give error information and return failed
                message = ex.Message;
                return Result.Failed;
I try to find Revit2015 Platform API Developers Guidelines without success, Does it exist anywhere?
mikako_harada
Are you looking for this documentation?
http://www.autodesk.com/revitapi-help
If so, could you try visit the latest version, following the above link, then try replacing version number in the url. e.g.,
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-F0A122E0-E556-4D0D-9D0F-7E72A9315A42
It should bring to the older version most of the time (There is a slight chance that if the page is newly added, it may not hit older one. Should work from the top basic pages.)
Mikako Harada
Developer Technical Services
OR_AND_NO
Thank You very mach for soon answer.
In Your reference the example (Code Region 29-14: Adjusting the analytical model in relation to another element http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-92AF0D57-2E97-4F42-8DE0-F308F89900C4) do not work in revit 2015 and 2016 without recoding so several examples from old version (2014) are not correct and i am looking for correct examples beacouse it's very dificult to understand api using uncorrect examples.
Have you downlaoded the SDK package for Revit 2015 and 2016?
OR_AND_NO
Sure, 2015 SDK
