Does not contain a definition for ‘Application’
aclarke
aclarke
Hi all,
I am working with C# in the SharpDevelop Revit Macro Manager.
I am creating a sub routine class outside of ThisDocument to be called into ThisDocument.
I am running into an error:
does not contain a definition for ‘Application’ and no extension method…
How can I create a subfunction that calls Revit UIDocument.  This sub function is within the same namespace as 'ThisDocument'
Thanks for any help!
jeremytammik
Look at the Revit API documentation, either in the Windows help file RevitAPI.chm in the Revit SDK or in the online help:
https://www.revitapidocs.com/
Document class:
https://www.revitapidocs.com/2020/db03274b-a107-aa32-9034-f3e0df4bb1ec.htm
Application property:
https://www.revitapidocs.com/2020/b517ce21-cec3-4cf3-e74b-aa0f219f6724.htm
Jeremy Tammik
Developer Technical Services
The Building Coder
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @aclarke ,
try using the below code
UIDocument uidoc=this.ActiveUIDocument;
Document doc=this.ActiveUIDocument.Document;
I hope this helps.
Naveen Kumar T
aclarke
Naveen
Thank you.  it was a combination of your answer and this other forum answer that helped me figure it out
thanks
https://forum.dynamobim.com/t/does-not-contain-a-definition-for-application/42517
UIDocument uidoc = new ThisDocument();
Document doc = new ThisDocument().Document;
