Does BoundingBoxIntersectsFilter works on element whose boundingbox in completely inside?
sahin.ikbal
sahin.ikbal
As it says boundingboxes needs to be intersecting I am a bit confused about it giving a positive result if bounding box is completely inside.
RPTHOMAS108
Good question.
I've not had the opportunity to test but if you have found the answer to be yes it does, then perhaps we should think of the bounding box as a solid volume.
If you want to check it is or isn't completely inside you can use BoundingBoxIsInsideFilter in conjunction with BoundingIntersectsFilter.  All these filters can also be inverted so many permutations to investigate.
You can't really get precise results with either of these because they are aligned with the model coordinate system i.e. a beam at 45 degrees gives a square rather than rectangular bounding box in the XY plane. They are used mainly for initial filtering of elements. They likely exist mirroring some internal function that allows Revit to quickly decide what to generate graphics for.
