Document Views Export for C#
bibal45271
Observer Observer
bibal45271
Observer
Observer
Hello, Revit API Forum.
I've needed to export some views in PDF format and everything seemed fine until I tried to export three hundred views, each in the separate PDF file 😅
As I understand, the only method, that can export PDFs is:
https://www.revitapidocs.com/2022/93d66d57-c20e-a103-39a1-77bc2ea05183.htm
But when I use it for many PDFs export, the application freezes on the 171st PDF.
(If a one big process is batched into two smaller processes, like 150 and 150, it works fine).
Is there any possible workaround for this problem in which it would be possible to export all 300 views without batching?
jeremy_tammik
Probably not. You could try to increase the size of your memory and hard disk etc. but every batch process will hit a limit eventually. Revit was implemented and tested with an end user in mind, with limited working time per day and limited patience. For serious batch processing, you either need to split it up into manageable batches, as you describe, or implement process logging and graceful handling of freezing, crashing and restarting to continue from where it broke off, cf.
