Document.SaveAsCloudModel Method cannot be used when current document is already in cloud
ptranU2KHX
ptranU2KHX
Hi everyone,
I am trying to use the SaveAsCloudModel method to upload my project to the ACC platform. However, the problem is that this method does not work if the project is already in the cloud. I do not want to delete the project manually before uploading it by API because I doubt that this action could break some workflow related to the cloud or workshare. Therefore, I wonder if there are any solutions to overwrite the project in the ACC platform.
Thank you.
jeremy_tammik
Im sure there are ways to detect whether the model is already a cloud model or not, so you could simply apply those and decide appropriately before calling SaveAsCloudModel.
The fact that it does not work on a model that is already in the cloud is intentional and clearly documented:
https://www.revitapidocs.com/2024/c72daf7a-43da-a480-d093-e3d6a96d9a76.htm
ptranU2KHX
@jeremy_tammik thanks for your response.
I totally understand and if you noticed, the title of this post is exposed from the Revit SDK document.
I'd like to ask for a solution that helps overwrite the existing document in the ACC platform.
jeremy_tammik
The appropriate place to submit such a wish is the Revit Idea Station. Whenever you require a new or enhanced Revit product or Revit API functionality, the Revit Idea Station is the place to go. Please search there for a corresponding wish list entry for the suggested functionality and add your comments to it, or create a new one, if none already exists:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Tag it as an API wish:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302/tab/most-recent/label-name/api
Ensuring that a wish gets as many votes as possible helps underline its importance to you and the rest of the developer community. The Revit Idea Station is currently one of the main driving input forces for Revit API enhancements. The Revit development team looks there. Your comment here in the discussion forum might be overlooked. Thank you!
ptranU2KHX
@jeremy_tammik it seems the API does not support my intent currently. Thank you.
