DockablePane & font size != 100%
FRFR1426
FRFR1426
I've made a dockable pane which hosts a WPF user control. It works OK, but if I go to Control Panel > Appearance and Personalization > Display and I change the size of the font for the entire system to 150%:
The WPF user control children do not resize themselves properly. I've got this result:
Note that the Textbox is truncated on the right. The width of the root grid is not correctly computed.
At 100%, it's OK.
There is a similar problem described here: https://bimdev.blogspot.fr/2014/11/revit-dockable-pane-failures-with.html but the solution presented does not work for me on Windows 10 - Revit 2016/2017
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
FRFR1426
I've found a solution. We can compensate by adding a margin to the root grid (grMain):
void UserControl_OnSizeChanged(object sender, SizeChangedEventArgs e)
    HandleTextScaling();
void HandleTextScaling() { PresentationSource source = PresentationSource.FromVisual(this); Debug.Assert(source != null, "source != null"); CompositionTarget target = source.CompositionTarget; Debug.Assert(target != null, "target != null"); Matrix m = target.TransformToDevice; double scale1 = m.M11; double scale2 = scale1 - 1; grMain.Margin = new Thickness(0, 0, scale2 * ActualWidth / scale1, scale2 * ActualHeight / scale1); }
Maxence DELANNOY
Manager
http://wiip.fr
