distinction between a shared parameter added to a family loaded into a project and project shared parameter
danielgijsbers
danielgijsbers
I would like to find out if a shared parameter has been added to a project through a loadable family or whether the shared parameter has been added through the project parameters dialogue box.
When I look with the snoop tool I can't find the differences between the two parameters.
I have added a rvt example with two shared parameters the parameter called 'NLRS_C_breedte' has come in through a family and the parameter called 'xxx-pmparam' has been added to the file as a project shared parameter.
please let me know
Omar_Amen
Hi @danielgijsbers,
I just noticed in GUI the project parameters contains only the parameters that has been added to the file as a project shared parameter:
 so I tried this code which retrieve all the project parameters (shared/project) and it returned only the 'xxx-pmparam'
 so you can use it to get all project parameter and then exclude the project parameters from the list,
you will get all parameters that has been added to the file as a project shared parameter not through a family
Omar_Amen
my code :
            List<string> result_KeyName = new List<string>();
            BindingMap map = doc.ParameterBindings;
            DefinitionBindingMapIterator it = map.ForwardIterator();
            it.Reset();
            while (it.MoveNext())
                result_KeyName.Add(it.Key.Name);
danielgijsbers
Thank you!
