Distinct XYZ
Distinct XYZ
MGO-Norsyn
Message 1 of 9
Distinct XYZ
MGO-Norsyn
Hi
I have a list of XYZ points (obtained from MEP connectors).
How to clean it of duplicates (e.g. XYZs with same coordinates)?
I am trying to:
var distinctElementConnectors = MyMepUtils.GetALLConnectorsFromElements(elements)
                                          .Where(c => c.IsConnected)
                                          .Distinct(c => c.Origin)
                                          .ToHashSet();
The .Distinct(c => c.Origin) doesn't work because .Distinct doesn't know how to compare XYZs (or does it?).
Please help.
Accepted solutions (3)
Replies (8)
Message 2 of 9
jeremytammik
Dear Michail,
Thank you for your very valid query.
You are absolutely correct:
The .NET API does not have any built-in mechanism to compare the Revit API XYZ objects.
However, it is easy to implement, and I have done so several times in different discussion published by The Building Coder.
Here are the first and last mentions so far:
While writing this, I note that The Building Coder samples define the class XyzEqualityComparer in three different modules:
I hope this helps and suits your needs.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 9
BobbyC.Jones
Another direction to go, assuming you implemented your own Point3D and Vector3D wrapper classes like we previously discussed is to have those classes implement the IEquatable interface.  Here's a shell of the Point3D class showing my implementation:
    public class Point3D : IEquatable<Point3D>
        public Point3D(XYZ revitXyz)
            XYZ = revitXyz;
        public XYZ XYZ { get; }
        public double X => XYZ.X;
        public double Y => XYZ.Y;
        public double Z => XYZ.Z;
        public bool Equals(Point3D other)
            if (ReferenceEquals(other, null)) return false;
            if (ReferenceEquals(this, other)) return true;
            return X.IsAlmostEqualTo(other.X) &&
                   Y.IsAlmostEqualTo(other.Y) &&
                   Z.IsAlmostEqualTo(other.Z);
public override bool Equals(object obj)
if (ReferenceEquals(null, obj)) return false;
if (ReferenceEquals(this, obj)) return true;
if (obj.GetType() != GetType()) return false;
return Equals((Point3D) obj);
} public override int GetHashCode() { return Tuple.Create(Math.Round(X, 10), Math.Round(Y, 10), Math.Round(Z, 10)). GetHashCode(); } }
Storing Point3D instances in a hashset will give you your distinct set of points.
                                          .Select(c => c.Origin.ToPoint3D())
                                          .ToHashSet();
Bobby C. Jones
Message 4 of 9
MGO-Norsyn
Thank you for your answer. As always, the solution is already implemented somewhere...
But more specifically I was thinking of a way to implement a routine to handle this comparison with LINQ.
Message 5 of 9
MGO-Norsyn
Thank you for replying.
Regrettably, I haven't had time to look into your wrapper classes, but I notice that you get a collection of distinct points, while I am interested in getting a collection of distinct connectors where distinction is based on if the origins coincide. 😉
Message 6 of 9
jeremytammik
I define a comparer class that does the job:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/U...
    /// <summary>
    /// Compare Connector objects based on their location point.
    /// </summary>
    public class ConnectorXyzComparer : IEqualityComparer<Connector>
      public bool Equals( Connector x, Connector y )
        return null != x
          && null != y
          && IsEqual( x.Origin, y.Origin );
      public int GetHashCode( Connector x )
        return HashString( x.Origin ).GetHashCode();
    /// <summary>
    /// Get distinct connectors from a set of MEP elements.
    /// </summary>
    public static HashSet<Connector> GetDistinctConnectors(
      List<Connector> cons )
      return cons.Distinct( new ConnectorXyzComparer() )
.ToHashSet(); }
I implemented that in The Building Coder samples release 2018.0.134.1:
https://github.com/jeremytammik/the_building_coder_samples/releases/tag/2018.0.134.1
Here is the diff to the previous release:
https://github.com/jeremytammik/the_building_coder_samples/compare/2018.0.134.0...2018.0.134.1
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 9
jeremytammik
Edited and summarised for posterity:
http://thebuildingcoder.typepad.com/blog/2017/08/birthday-post-on-the-xyz-class.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 9
this is how i do to sort and distinct list of XYZ:
Debug.Print("All Points");
i = 0;
foreach (XYZ xyz in lstxyzPoints) {
i++;
Debug.Print(i.ToString() + " - " + xyz.ToString());
List<XYZ> lstxyzPointsDistinct = GetDistinctPoints(lstxyzPoints);
Debug.Print("Distinct Points");
i = 0;
foreach (XYZ xyz in lstxyzPointsDistinct) {
i++;
private List<XYZ> GetDistinctPoints(List<XYZ> lstxyz) {
List<XYZ> lstxyzRound = new List<XYZ>();
int i = 1, j = 1;
//round the points to 6 decimal places (you may not need this)
foreach (XYZ xyz in lstxyz) {
lstxyzRound.Add(new XYZ(Math.Round(xyz.X, 6), Math.Round(xyz.Y, 6), Math.Round(xyz.Z, 6)));
//order by Z,X,Y (depends on your need)
lstxyzRound = lstxyzRound.OrderBy(p => p.Y).ToList();
lstxyzRound = lstxyzRound.OrderBy(p => p.X).ToList();
lstxyzRound = lstxyzRound.OrderBy(p => p.Z).ToList();
//remove points from list if duplicates
bool blnDuplicate = true;
while (blnDuplicate) {
blnDuplicate = false;
for (i = j; i < lstxyzRound.Count; i++) {
if (lstxyzRound[i - 1].DistanceTo(lstxyzRound[i]) < 0.0001) {
j = i;
break;
if (blnDuplicate) {
lstxyzRound.RemoveAt(j);
return lstxyzRound;
Message 9 of 9
MGO-Norsyn
While implementing Jeremy's ConnectorXYZComparer, I've discovered that some connector groups can have much larger tolerances than the 1.0e-9 that Jeremy uses, which gives false negatives. For details see my post in another thred.
