DisplayUnitType in Revit 2022
pmeigneux
pmeigneux
When compile with Revit 2022 : Error CS0122 'DisplayUnitType' is inaccessible due to its protection level
Have you a solution ?
jeremy_tammik
pmeigneux
I am looking for the type of unit from a character string.
value1 = string (example : "DUT_METERS",   "DUT_SQUARE_METERS",  "DUT_WATTS_PER_SQUARE_METER_KELVIN")
my code :
DisplayUnitType RevitMKS = DisplayUnitType.DUT_GENERAL;
if (value1 != "")
    foreach (DisplayUnitType P in Enum.GetValues(typeof(DisplayUnitType)))
        if (P.ToString() == value1)
            RevitMKS = P;
            break;
how to do the equivalent?
pmeigneux
Have you list of string value for ForgeTypeId(String typeId); ?
jeremy_tammik
The method ListForgeTypeIds in The Building Coder samples Util.cs module probably does that for you:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/U...
dmitry.dronov
Sorry, but page not found.
Yes, but ))
It is the same info?
The Building Coder: ForgeTypeId and Units Revisited (typepad.com)
