Display View on Second Monitor Macro
Hello All,
This is a general question regarding api capabilities.  Is it possible to create a macro that will allow a view to be dragged outside of Revit and docked on a second monitor in the same way the project browser can?  Or, is adding that functionality not possible with the api?
jeremytammik
Dear Energygroup,
Thank you for your query.
I am not aware of any support at all in the Revit API for accessing or managing multiple screens.
If that can be done with the Revit project browser, I would assume that that functionality is somehow built into and provided by Windows itself.
However, if the project browser can be dragged to a separate screen, then I would assume that a dockable panel can as well.
Dockable panels can indeed be implemented using the Revit API:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.4
Since a ready-made dockable panel is provided as a Revit SDK sample, you can try it out for yourself right away.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Is it possible to create a view window that is allowed to move outside Revit, or to show a view in a dockable panel?
