Discrepancy Between Revit Rebar Length in Properties and Manual Calculation
veeresh.huvinahalliACK3L
Hi everyone,
I'm working with rebar in Revit, and I've encountered an issue with the rebar length shown in the properties tab. When I manually calculate the rebar length by summing the dimensions (segments, hooks, etc.), the total I get doesn't match the length displayed in Revit's properties tab.
I'm wondering if I'm making a mistake in my calculations or if there's an additional factor that Revit includes when calculating rebar length.
Has anyone else faced this issue? Is there a recommended approach to ensure that the manually calculated rebar length matches what Revit is showing? Are there specific dimensions or adjustments that Revit accounts for that I might be overlooking?
veereshhuvinahalliACK3L_0-1725610280945.pngveereshhuvinahalliACK3L_1-1725610290834.png
MarryTookMyCoffe
wrong forum
do not worry it only gonna take Autodesk 5 years to fix bug
