Disconnect connector from adjacent fitting
I am attempting to split a duct in two which is a topic that has been covered on this forum before, a good solution appears to be suggested here: http://forums.autodesk.com/t5/revit-api-forum/pipe-duck-spliting-using-the-revit-api/m-p/3312303/hig...
The first step is to disconnect the pipe or duct from any fittings that might be attached at the end to be shortened, this is where I am struggling.
I can grab the connector no problem and it looks like connector1.DisconnectFrom(connector2) should do the trick but I am not able to find the relevant connector2 to disconnect from. I have tried connector1.GetMEPConnectorInfo().LinkedConnector but that returns null even when connector.IsConnected returns true.
Could anyone point me in the direction of a method to obtain the connector(s) which are connected to a given connector?
matthew_taylor
Hi Darren,
If you're using 2017, then BreakCurve looks like what you need: http://www.revitapidocs.com/2017/baeec9be-b43d-d378-31b9-453432d44bfb.htm
If the duct you are trying to get connector info from was created in the same macro, you may need to either start a new transaction or do a doc.regenerate in order to receive fresh data.
There is an example of how to find a connected element here: http://www.revitapidocs.com/2017/11e07082-b3f2-26a1-de79-16535f44716c.htm
Does that help?
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Thanks Matt, the connector.AllRefs method in the example you linked has done the trick for me!
BreakCurve sounds fantastic but at this stage I need target 2016.
