DirectShape Properties
Message 1 of 11
Hi guys,
I have a simple tester method that is creating a DirectShape object which is defined inside the Generic Categroy. But I am wondering if it is posible to add further properties to the object, I cant seem to find the way to do so in the API. I am also quite puzzled why by defualt it is set to Structural it would be great to be able to add / modify the defualt properties with which this DirectShape object  comes with.
Any guidance would be great (:
The below method is within a Zero Touch Node:
 public static void CreateDirectShapeB(bool run, double width, double height)
            // Get current document
            Autodesk.Revit.DB.Document doc = DocumentManager.Instance.CurrentDBDocument;
            // Initilaize transaction
            TransactionManager.Instance.EnsureInTransaction(doc);
            if (run)
                try
                    List<XYZ> pts = new List<XYZ>();
                    XYZ center = XYZ.Zero;
                    XYZ topRightCorn = center + new XYZ(width, width, 0);
                    XYZ bottomRightCorn = center + new XYZ(width, width*-1, 0);
                    XYZ topLeftCorn = center + new XYZ(width*-1, width, 0);
                    XYZ bottomLeftCorn = center + new XYZ(width * -1, width * -1, 0);
                    pts.Add(topRightCorn);
                    pts.Add(topLeftCorn);
                    pts.Add(bottomLeftCorn);
                    pts.Add(bottomRightCorn);
                    Autodesk.DesignScript.Geometry.PolyCurve bounds =  PolyLine.Create(pts).ToProtoType();
                   var solid = bounds.ExtrudeAsSolid(Autodesk.DesignScript.Geometry.Vector.ZAxis(), height);
                    Autodesk.Revit.DB.DirectShape ds = Autodesk.Revit.DB.DirectShape.CreateElement(doc, new ElementId(BuiltInCategory.OST_GenericModel));
                    ds.SetShape(solid.ToRevitType());
                    ds.Dispose();
                catch (Exception ex)
                    throw new ArgumentException(ex.ToString());
            TransactionManager.Instance.TransactionTaskDone();
Replies (10)
Message 2 of 11
jeremytammik
Why do you call `Dispose` on the newly created direct shape? That seems very weird. Maybe that call is messing it up somehow.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 11
Moustafa_K
Usually, adding parameter is via adding a shared parameter via Revit API, check this link it will give you more information
https://spiderinnet.typepad.com/blog/2011/05/parameter-of-revit-api-26-create-shared-parameter.html
I hope that helps
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Message 4 of 11
@Moustafa_K thanks for the link!
I actually modified the method to fit my needs a little more. I actually assign those properties in code to the Area elements (for know) But I will have to add another functionality to only pick certain Generic Mass Elements from the Revit document. What I mean by that is to only assign those Shared Parameters to the created Direct Shape Masses which are of a Generic Mass Category. Ignore all the mess at the end of the method: options2...  areaSharedParamDef2...
I will refine this later.
Here is the method:
  private static void CreateSharedParameter(Autodesk.Revit.DB.Document doc, string name, string group, ParameterType type)
            try
                DefinitionFile defFile = doc.Application.OpenSharedParameterFile();
                String modulePath = Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location);
                String paramFile = modulePath + "\\AreasSharedParameters.txt";
                // check whether shared parameter exists
                if (defFile == null)
                    // create shared parameter file
                    if (File.Exists(paramFile))
                        File.Delete(paramFile);
                    FileStream fs = File.Create(paramFile);
                    fs.Close();
                else
                    // cache application
                    Autodesk.Revit.ApplicationServices.Application revitApp = doc.Application;
                    // prepare shared parameter file
                    revitApp.SharedParametersFilename = paramFile;
                    // open shared parameter file
                    DefinitionFile parafile = revitApp.OpenSharedParameterFile();
                    // create a group
                    DefinitionGroup apiGroup = parafile.Groups.Create(group);
                    ExternalDefinitionCreationOptions options = new ExternalDefinitionCreationOptions(name, type);
                    ExternalDefinitionCreationOptions options2 = new ExternalDefinitionCreationOptions("Comments", ParameterType.Text);
                    // create parameter
                    Definition areaSharedParamDef = apiGroup.Definitions.Create(options);
                    Definition areaSharedParamDef2 = apiGroup.Definitions.Create(options2);
                    // get Areas category
                    Autodesk.Revit.DB.Category areaCat = doc.Settings.Categories.get_Item(BuiltInCategory.OST_Areas);
                    CategorySet categories = revitApp.Create.NewCategorySet();
                    categories.Insert(areaCat);
                    // insert the new parameter
                    InstanceBinding binding = revitApp.Create.NewInstanceBinding(categories);
                    doc.ParameterBindings.Insert(areaSharedParamDef, binding);
                    doc.ParameterBindings.Insert(areaSharedParamDef2, binding);
                throw new Exception("Failed to create shared parameter: " + ex.Message);
            // Finalize transaction
Called within another method wrapped in a Dynamo node:
    public static void CreateSharedParameter()
            CreateSharedParameter(doc, "Volume", "Areas Custom Properties", ParameterType.Volume);
@jeremytammik thank you as well for your prompt reply!  I did remove the Dispose() but I still got those weird properties. I thought that since I am not returning the actually geometry from the method I had to manually dispose it from the Dynamo node, but I guess not?
But I have a much more worrysome problem I am having! The previous method I posted above was actually a separate test that I was doing, because when I try to use it with my actual geometry  Dynamo and Revit freeze for some strange reason, and I dont have any idea why.
By the way I also found this post in your blog that is quite similar to what I am trying to do and it was very helpful:
https://thebuildingcoder.typepad.com/blog/2019/05/generate-directshape-element-to-represent-room-vol...
Its great how you added the Rooms properties in to its corresponding Direct Shape
here is the whole method:
[Autodesk.DesignScript.Runtime.MultiReturn(new[] { "Volumnes","Heights", "Boundary Curve", "Area Names"})] // wrappedRevitLevel
public static Dictionary<string, object> GetAreasByProperties(List<wrappedRevitElement> areaObjects, wrappedRevitLevel level, List<wrappedRevitElement> levelObjects, string inputAreaName,
bool filterByName, bool filterByLevel)
SpatialElementBoundaryOptions bOptions = new Autodesk.Revit.DB.SpatialElementBoundaryOptions();
// Create Revit Element list
List<unwrappedRevitElement> revitElements = new List<unwrappedRevitElement>();
List<string> JsonStrings = new List<string>();
// Create Level Elevation list
List<double> areaObjectElevations = new List<double>();
List<Area> areaObjectsTemp = new List<Area>();
// Loop through all wrapped Revit Elements and unwrapp them
for (int i = 0; i < areaObjects.Count; i++)
revitElements.Add(areaObjects[i].InternalElement);
// Convert Dynamo Level to Revit Level
unwrappedRevitLevel revitLevel = level.InternalElement as Autodesk.Revit.DB.Level;
// Get all Area object names
List<string> objectAreaNames = GetAllParametersByName(areaObjects,"Name");
// filter by name
string areaObjectName = GetAreaName(objectAreaNames, inputAreaName);
////////////////////////////////////////////// OUTPUTS //////////////////////////////////////////////
List<Autodesk.DesignScript.Geometry.PolyCurve> boundary = new List<Autodesk.DesignScript.Geometry.PolyCurve>();
List<string> areaNames = new List<string>();
List<double> heights = new List<double>();
List<Autodesk.DesignScript.Geometry.Solid> volumes = new List<Autodesk.DesignScript.Geometry.Solid>();
List<Autodesk.DesignScript.Geometry.Curve> crvs = new List<Autodesk.DesignScript.Geometry.Curve>();
#region FILTER BY NAME AND BY LEVEL
if (filterByName == true && filterByLevel == true)
XYZ firstCrvSrtPoint = new XYZ();
Area areaObj = null;
foreach (var item in revitElements)
if (item.Category.Name == "Areas")
areaObj = item as Area;
areaObjectElevations.Add(areaObj.Level.Elevation);
areaObjectsTemp.Add(areaObj);
if (areaObjectName == inputAreaName && areaObj.Level.Name == revitLevel.Name)
areaNames.Add(areaObj.Name);
List<XYZ> BoundaryCrvSegmentEndpoints = new List<XYZ>();
if (areaObj.Area <= 0) throw new ArgumentException("Area Element must have an Area greater than 0!");
else
string json = CreateJsonFromElementProperties(areaObj);
JsonStrings.Add(json);
IList<IList<BoundarySegment>> boundSegments = areaObj.GetBoundarySegments(bOptions);
for (int i = 0; i < boundSegments.Count; i++)
IList<BoundarySegment> data = boundSegments[i];
int count = 0;
for (int j = 0; j < data.Count; j++)
crvs.Add(data[j].GetCurve().ToProtoType());
count++;
if (count == 1)
Curve c = data[j].GetCurve();
firstCrvSrtPoint = c.GetEndPoint(0);
c.Dispose();
Curve unwrappedRevitCurve = data[j].GetCurve();
BoundaryCrvSegmentEndpoints.Add(unwrappedRevitCurve.GetEndPoint(0)); // 0 index for start point
// Dispose unwrappedRevitCurve Revit curve
unwrappedRevitCurve.Dispose();
BoundaryCrvSegmentEndpoints.Add(firstCrvSrtPoint);
boundary.Add(PolyLine.Create(BoundaryCrvSegmentEndpoints).ToProtoType());
//dispose points after used to create polyline
foreach (XYZ point in BoundaryCrvSegmentEndpoints)
point.ToPoint().Dispose();
else
throw new ArgumentException("Your Elements need to be of Category of type Area!");
bOptions.Dispose();
firstCrvSrtPoint.ToPoint().Dispose();
if (boundary.Count == 1)
unwrappedRevitLevel nextLevelUp = GetNextLevelUp(areaObj, levelObjects);
double nextLevelUpElevation = nextLevelUp.Elevation * 304.8; // convert decimal feet to mm
double areaObjElevation = areaObj.Level.Elevation * 304.8; // convert decimal feet to mm
double extrusionHeight = nextLevelUpElevation - areaObjElevation;
heights.Add(extrusionHeight);
// Create volumes
for (int i = 0; i < boundary.Count; i++)
Autodesk.DesignScript.Geometry.Solid solid = boundary[i].ExtrudeAsSolid(Autodesk.DesignScript.Geometry.Vector.ZAxis(), extrusionHeight);
volumes.Add(solid);
 CreateDirectShape(doc, solid, JsonStrings[i], areaNames[i]);
if(boundary.Count > 1)
// // Sort area objects on their height
//List<Area> sortedAreaObjects = SortAreaObjectsOnHeight(areaObjectsTemp);
// for (int i = 0; i < sortedAreaObjects.Count; i++)
// // Get the current Area Object's upper level
// unwrappedRevitLevel nextLevelUp = GetNextLevelUp(sortedAreaObjects[i], levelObjects);
// // Calculate extrusion height
// double extrusionHeight = (nextLevelUp.Elevation * 304.8) - (sortedAreaObjects[i].Level.Elevation * 304.8);
// heights.Add(extrusionHeight);
// for (int i = 0; i < boundary.Count; i++)
// // NOTE : SOLID CLASS CONTAINS METHOD TO CRERATE FAMILY TYPE!
// Autodesk.DesignScript.Geometry.Solid solid = boundary[i].ExtrudeAsSolid(Autodesk.DesignScript.Geometry.Vector.ZAxis(),heights[i]);
// volumes.Add(solid);
return new Dictionary<string, object>
{"Volumnes", volumes },
{"Heights", heights },
{"Boundary Curve", boundary },
{"Area Names", areaNames },
Sorry for such a long post and thanks again!
Message 5 of 11
Here is the method:
            try
                    fs.Close();
                else
                    // create a group
                    // create parameter
Called from within another method wrapped in a Dynamo node:
Message 6 of 11
@Anonymous thank you as well for your prompt reply!  I did remove the Dispose() but I still got those weird properties. I thought that since I am not returning the actually geometry from the method I had to manually dispose it from the Dynamo node, but I guess not?
            // filter by name
                            else
                                    int count = 0;
                                        count++;
                                        if (count == 1)
                                            c.Dispose();
                    else
                bOptions.Dispose();
                    // Create volumes
                        volumes.Add(solid);
Message 7 of 11
Here is the method:
            try
                    fs.Close();
                else
                    // create a group
                    // create parameter
Message 8 of 11
I forgot to include the method were the Direct Shape is created:
     private static void CreateDirectShape( Autodesk.Revit.DB.Document doc, Autodesk.DesignScript.Geometry.Solid volume, string json, string name)
            try
                IList<GeometryObject> solids = volume.ToRevitType();
                Autodesk.Revit.DB.DirectShape ds = Autodesk.Revit.DB.DirectShape.CreateElement(doc, directShapeIDCategory);
                ds.SetShape(solids.ToList<GeometryObject>());
                ds.get_Parameter(_bip_properties).Set(json);
                ds.Name = "Area volume for " + name;
Message 9 of 11
Is it possible to select Solid of direct shape then create family? thankyou !
Message 10 of 11
jeremy_tammik
Message 11 of 11
Can I create a Family from Solid by DirectShape?
