Direction of Reference (Reference Plane or Reference Line)
desdinova
Message 1 of 18
desdinova
FamilyInstance familyInstance = element as FamilyInstance;
IList<Reference> familyInstanceReferences = familyInstance.GetReferences(FamilyInstanceReferenceType.StrongReference);
foreach (Reference familyInstanceReference in familyInstanceReferences)
// I want to get direction of reference
Hello friends,
In 2018 version i can get the reference in familyinstance directly.
But i want to get the direction of references(reference planes or reference lines)
How can i achieve this?
Line line = doc.GetElement(reference).GetGeometryObjectFromReference(reference) as Line;
didnt work for me.
Thanks in advance...
Replies (17)
Message 2 of 18
IbrahimNaeem
//Have you tried to get the location and acquire the line from there.
LocationCurve loc = doc.GetElement(ref).Location as LocationCurve;
XYZ Frst = loc.Curve.GetEndPoint(0);
Thanks, Ibrahim Naeem
Message 3 of 18
desdinova
Thanks.
I tried.
it didnt work
Message 4 of 18
IbrahimNaeem
Are you sure that these family instances are created as line based  ?
Message 5 of 18
desdinova
I think
there is no need to use line based family
my code is
try
                Line dimensionLine = null;
                ReferenceArray firstArray = new ReferenceArray();
                FamilyInstance familyInstance = doc.GetElement(uidoc.Selection.PickObject(ObjectType.Element)) as FamilyInstance;
                XYZ point = uidoc.Selection.PickPoint("Select first point");
                XYZ difference = new XYZ(200, 0, 0);
                dimensionLine = DimensionUtils.CreateLine(doc, point, difference);
                    firstArray.Append(familyInstanceReference);
                using (Transaction t = new Transaction(doc, "Add Dimension"))
                    t.Start();
                    Dimension dimension = doc.Create.NewDimension(doc.ActiveView, dimensionLine, firstArray);
                    t.Commit();
            catch(Exception ex)
                TaskDialog.Show("Error", ex.Message);
Message 6 of 18
FAIR59
I think an adepted version of my answer to the discussion on a  Dimension on Hatch Pattern Slab https://forums.autodesk.com/t5/revit-api-forum/dimension-on-hatch-pattern-slab/m-p/7079252#M22790 will work for you.
Here's my code
        public XYZ GetReferenceDirection(Reference ref1, Document doc)
        // returns the direction perpendicular to reference
        // returns XYZ.Zero on error;
            XYZ res = XYZ.Zero;
            XYZ workPlaneNormal = doc.ActiveView.SketchPlane.GetPlane().Normal;
            if (ref1.ElementId == ElementId.InvalidElementId) return res;
            Element elem = doc.GetElement(ref1.ElementId);
            if (elem == null) return res;
            if (ref1.ElementReferenceType == ElementReferenceType.REFERENCE_TYPE_SURFACE || ref1.ElementReferenceType == ElementReferenceType.REFERENCE_TYPE_LINEAR)
                // make a dimension to a point for direction
                XYZ bEnd = new XYZ(10, 10, 10);
                ReferenceArray refArr = new ReferenceArray();
                refArr.Append(ref1);
                Dimension dim = null;
                using (Transaction t = new Transaction(doc, "test"))
                    t.Start();
                    using (SubTransaction st = new SubTransaction(doc))
                        st.Start();
                        ReferencePlane refPlane = doc.Create.NewReferencePlane(XYZ.Zero, bEnd, bEnd.CrossProduct(XYZ.BasisZ).Normalize(), doc.ActiveView);
                        ModelCurve mc = doc.Create.NewModelCurve(Line.CreateBound(XYZ.Zero, new XYZ(10, 10, 10)), SketchPlane.Create(doc, refPlane.Id));
                        refArr.Append(mc.GeometryCurve.GetEndPointReference(0));
                        dim = doc.Create.NewDimension(doc.ActiveView, Line.CreateBound(XYZ.Zero, new XYZ(10, 0, 0)), refArr);
                        ElementTransformUtils.MoveElement(doc, dim.Id, new XYZ(0, 0.1, 0));
                        st.Commit();
                    if (dim != null)
                        Curve cv = dim.Curve;
                        cv.MakeBound(0, 1);
                        XYZ pt1 = cv.GetEndPoint(0);
                        XYZ pt2 = cv.GetEndPoint(1);
                        res = pt2.Subtract(pt1).Normalize();
                    t.RollBack();
            return res;
Message 7 of 18
desdinova
Thank you FAIR59,
It is working...
Message 8 of 18
Did you modify FAIR59's code or are using the posted version? I am trying to get the direction of the reference but FAIR59's version returns the direction perpendicular direction whilst I am looking for the direction itself (parallel).
thanks in advance.
Message 9 of 18
desdinova
I use FAIR59's code
for check the direction, i use this
                                if (DimensionUtils.GetReferenceDirection(doc, familyInstanceReference).ToString() == XYZ.BasisX.ToString() ||
                                   DimensionUtils.GetReferenceDirection(doc, familyInstanceReference).ToString() == XYZ.BasisX.Negate().ToString())
Message 10 of 18
Hi FAIR59,
Your code is returning the perpendicular direction perfectly, but can this be modified to return the parallel direction? I am trying tot modify this but I am stuck at the moment.
Thanks in advance,
Raymond
Message 11 of 18
FAIR59
to get a 90 degree different direction, you need to establish the plane in which to "rotate".
The most obvious plane is off course the sketch plane of the view.
the normal for that plane is: doc.ActiveView.ViewDirection
instead of :
    return res;
use:
    return doc.ActiveView.ViewDirection.CrossProduct(res);
Message 12 of 18
That easy huh :). Will give it a shot.
Message 13 of 18
Thanks!!
Message 14 of 18
mastjaso
Hey @FAIR59 this code does seem to work well for returning the normal of the reference plane, provided that the reference plane is oriented vertically. But this doesn't seem to work if your reference plane is horizontal. I've looked through it, and I think I somewhat understand how your function is working (somewhat.), but I can't figure out how it could be adapted to truly work in any direction. I suspect it's not possible based on the fact that you're having to use a dimension created in this view, however, I was wondering if you had any ideas?
Message 15 of 18
FAIR59
The function makes the temporary dimension in the active view. If the active view is a planview, then yes only the vertical planes will be found.
To make the function more general, you could loop through all the views in the document, in the hope of finding a view that gives a result. ( no garanties )
IEnumerable<View> views = new FilteredElementCollector(doc)
				.OfClass(typeof(View));
foreach(View v in views)
	if (v.IsTemplate) continue;
	XYZ rightdirection = v.RightDirection;
	dim = doc.Create.NewDimension(doc.ActiveView, Line.CreateBound(XYZ.Zero, rightdirection.Multiply(10)), refArr);
	if (dim!=null) break;
if (dim !=null)
Message 16 of 18
paolomod3nese
Hi desdinova!
I'm trying to achieve exactly what you wanted to do: get the direction of references in a FamilyInstance.
I can't seem to find the
DimensionUtils
class in the API. Is this a custom class? If so, can you point me to the right direction on what class or method should I be searching for to get the direction of a reference?
Cheers,
Paolo
Message 17 of 18
desdinova
Hi Paolo,
Yes it is a custom class.
You can use
public static XYZ GetReferenceDirection(Document doc, Reference reference)
            XYZ res = XYZ.Zero;
            if (reference.ElementId == ElementId.InvalidElementId)
                return res;
            Element elem = doc.GetElement(reference.ElementId);
            if (elem == null)
                return res;
            if (reference.ElementReferenceType == ElementReferenceType.REFERENCE_TYPE_SURFACE || reference.ElementReferenceType == ElementReferenceType.REFERENCE_TYPE_LINEAR)
                refArr.Append(reference);
                    t.Start();
                        st.Start();
                        st.Commit();
                    if (dim != null)
                        cv.MakeBound(0, 1);
                    t.RollBack();
            return res;
It works for me.
Cheers
Message 18 of 18
BKSpurgeon
Hi @FAIR59
Thanks for your answer + the code you are providing.
It isn't altogether clear (to me) what you are doing (and why) in certain parts of your code?
