Direction for One-Way AnalyticalPanel
jorge.bslu
jorge.bslu
I have an analytical panel with AnalyzeAs = One-Way.
Is there any way to get information about that direction?
I haven't found any property, any parameter any clue in documentation.
It does not have any physical parent.
RPTHOMAS108
Can't see a way of doing this.
You can get the transform that represents the local coord system for the panel but not set it. Furthermore if you rotate the panel element itself but apply the original outline position the local system rotates back. Seems to decide orientation based on outline.
Seems an odd omission since direction of panel is obviously important for the consideration of the stiffness in each direction of the panel i.e. what are the directions.
