Direct Integration between Civil3d and Revit
Can we capture the civil3d coordinates directly to a revit model using automation @Anonymous serra.?
jeremytammik
Dear Sathishkumar,
Thank you for your query.
It is not possible to answer as it stands... too little information for me, at least.
When you say 'automation', do you mean Forge Design Automation?
If so, your question will be better answered by submitting it to the official Forge help channels.
Please note that this discussion forum is dedicated to programming desktop Revit using the desktop Revit API.
For all Forge-related questions, you should ask through the dedicated Forge help channels:
https://forge.autodesk.com/en/support/get-help
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi ,
Automation in the sense , am trying to use dynamo .Can we use dynamo to take coordinates from civil3d to revit model.
jeremytammik
Dear Sathishkumar,
Thank you for your update and clarification.
Well, as you certainly know, you can definitely use Dynamo to 'take coordinates to the Revit model'.
Of course, it completely depends on what you mean by 'take'.
Yet again, you might want to be more specific.
If you just ask 'can I take', my answer will always be 'yes'.
It depends on how. At a certain point I will (hopefully, for my own sake) revert to 'no'.
Obviously, I cannot say anything about the Civil3D side of things.
You might want to discuss that in the Civil3D programming forum.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Still waiting for clear view about the dynamo stuff for this coordinates issues
