Dimension Value Ovveride
Message 1 of 8
Hi all,
Tell me please, how to override value for Dimension from API (C#)?
Thanks.
Replies (7)
Message 2 of 8
rosalesduquej
Dear Aleksandr,
Have you tried using Dimension.ValueOverride Property
http://revitapisearch.com/html/4560ec6c-5aab-fcae-a64c-6f939ae06d94.htm
Hope it helps.
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Message 3 of 8
Thank you Jaime,
I have seen that, but I do not know how to apply... Tried in different ways, sometimes Revit crashes. It would be nice to get a ready example.
Thanks.
Message 4 of 8
BobbyC.Jones
I have also observed a Revit crash when accessing a DimensionSegment.ValueOverride property via a System.AccessViolationException when the .ValueOverride property has no value.  It will also crash if the .Below, .Above, .Prefix, or .Suffix properties are accessed when they contain no value.
I found a workaround on stackoverflow, How to handle AccessViolationException, which has links to some addition articles on MSDN.
Basically you wrap reads to those properties in a Try/Catch block and decorate the calling method with a [HandleProcessCorruptedStateExceptions] attribute  (The stackoverflow link has other solutions but this is the only one that I've tried).
        private void GetOverride(Dimension singleSegmentDimension)
            try
                ValueOverride = singleSegmentDimension.ValueOverride;
            catch (System.AccessViolationException ex)
                //Handle the scary "Attempted to read or write protected memory. This is often an indication that other memory is corrupt." message...
Bobby C. Jones
Message 5 of 8
Thanks Bobby, but... I want write different value to Value Override of Dimension.
Message 6 of 8
BobbyC.Jones
I haven't tested yet, but this may have been addressed in 2016 SP2 per the release notes.
  • Improves stability when DimensionSegment ValueOverride API is called when the dimension value was not overridden.
Bobby C. Jones
Message 7 of 8
tdaniel
Does the crash happen on Single or Multi-Segment Dimensions or both?
Message 8 of 8
BobbyC.Jones
Both.
<unrelated side rant>
I REALLY HATE that we have to handle single and multiple segments differently!  Sorry, but sometimes you just gotta let that stuff out  🙂
Bobby C. Jones
