DIMENSION FOR BEAMS....
ntdat024
ntdat024
I try to create an add-in to dim between beams. after the finish, I can't  Edit Witness Lines because ElementRefercence Type is REFERENCE_TYPE_NONE. ( ----> REFERENCE_TYPE_SURFACE).  Please see my picture below to get a better understanding of my problem. Please help me!!!
snabil76
Not all faces have a references,  many time I have allot of faces more than I see in the element.
Alwayes I check planerface reference if != null then I consider in my reference array
To reply to your question
1) check if planerface reference is not equal null
2) classify the planerface according to their directions
3) collect reference array for each direction separate
4) Run newdimension class
Hope if above cover your question
Best Regards
Sameh Nabil
