Different Min & Max values for Element BoundingBoxXYZ when it's looked up on a 3D view and on a Section view
MiguelGT17
MiguelGT17
Dear community, It's not quite clear why the element bounding box coordinates do not have the same value when I do look it up on a section view against looking it up on a 3D view
Floor plan to give you some context:
  • lookup on the section view:
  • lookup on a 3D view:
the Min.Z value is slightly different. The same situation occurs for other elements with greater tolerance as shown below:
  • BB coordinates when I hit the Lookup tool on a 3D VIEW
  • BB coordinates when I hit the Lookup tool on a SECTION VIEW
What is making those values differ from each other?
Kind regards,
Miguel G
RPTHOMAS108
RevitAPI.chm Element.BoundingBox Remarks:
"... Also note that this bounding box volume may enclose geometry that is not obvious. For example, the "flip controls" that could be part of a family will be included in the computation of the bounding box even though they are not always visible in the family instance of the family."
For your example you have the tick boxes in different positions per view perhaps. I would construct the bounding box in model lines to get an idea of what it is encompassing. However as noted the thing it is encompassing may be hidden.
