Determine if element is ElementType
I'm listening to the Application.DocumentChanged event and I would like to see if the element modified is an Instance or an ElementType. I'm currently doing the following but it doesn't quite satisfy all the conditions. I'm not native to Revit sorry if my terminology is off. How does the `FilterCollector.WhereElementIsElementType()` determine it's an ElementType?
private static bool IsElementType(Element element)
    var typeId = element?.GetTypeId();
    if (typeId == null || typeId == ElementId.InvalidElementId)
        if (!(element is Room) && !(element is PipeSegment))
            return true;
    return false;
RPTHOMAS108
//This will return false if type is ElementType but true if is derived from ElementType
bool Bl = element.GetType().IsSubclassOf(typeof(ElementType));
//This will return true if type is ElementType or is derived from ElementType
bool B2 = typeof(ElementType).IsAssignableFrom(element.GetType());
RPTHOMAS108
Here's a more Revit orientated approach you asked how a collector determines an ElementType but you can always pass a list of a single element into a collector and filter that:
Dim FEC As New FilteredElementCollector(element.Document, {element.Id}.ToList)
Dim B3 As Boolean = FEC.WhereElementIsElementType.ToElementIds.Count > 0
You can't do it in C# in this abbreviated fashion due to the need to use ICollection<T> directly (option Strict off in vb)  but you can do similar.
mhannonQ65N2
Here's a simpler way of putting it.
    return element is ElementType;
I'd suggest not even making a method for this and just using the is expression.
Sean_Page
I use the "is" operator quite often in my work.
Here is an online method which will give you the EType as a variable:
if(element is ElementType EType)
    TaskDialog.Show("Type Name",EType.Name);
Sean Page, AIA, NCARB, LEED AP
Senionr Partner, Computational Designer, Architect
RPTHOMAS108
Interesting to note that in VB the 'is' statement only returns true if the exact same type is compared. Since 'is' is used to check if two things are the same object instance. The equivalent to the way it is used in C# seems to be:
Dim B1 As Boolean = TypeOf Element Is ElementType
Which is something I've never really used to be honest.
