Determine element phase visibility status for the current 3d view
pfk
pfk
Hi
I would like to determine if a specific Element is visible in the current 3d View (ActiveView).  How can this be done pls taking into account the phase?  Element.IsHidden() returns False for demolished elements.  Revit2014 c#.
Paul
Revit will only report visible when you select an element in the phase it's created in. So what I once did is to loop through all phases in the project and see if the element I need is visible at this specific phase.
Something like:
FilteredElementCollector phaseColl = new FilteredElementCollector(doc).OfClass(typeof(Phase));
foreach (Phase ph in phaseColl.Cast<Phase>().Where(ph => ph != null))
  see if element is created in this phase and if it's visible
