Determine Document State ? DisplayedInUI : InBackground
lwlXUTTT
lwlXUTTT
Dear Community,
Is there any fast/clean method to determine whether the document has been opened and activated in UI oraz just runs in the background?
I used to check it this way:
doc.ActiveView != null
but I was wondering if there is any better way,
any help much appreciated
/Lukasz
jeremy_tammik
The approach you describe is exactly what came to mind. If it works, it sounds like a good one to me.
floretti
Hi Lukasz, were you successful on your approach? I'm trying to do the same but via the Revit Lookup I found that only the active document has a not null active view. Thank you.
lwlXUTTT
Hi @floretti ,
I was not aware of that...
But then another solution that comes to my mind is:
https://www.revitapidocs.com/2015/1ac8b262-9085-07e9-cef6-85377e8c70f3.htm
if list of ViewIds > 0 then
Document is opened and activated
please let me know whether it works for you,
Best, Lukasz
floretti
I tried but in order to get the OpenUIViews you need to loop through each document making it active in the UI.
ActiveUIDocument.GetOpenUIViews();
After some research I found out that there are (still) no native ways to activate open documents (refer to this article) and the effort won't outweigh the benefits I'll get from this so I'm dropping it.
