Detail Lines not updating until engaged in model space
normnoe
normnoe
I'm changing the line color of a detail line type within a transaction.  The change works correctly, but visually the lines do not change color until engaged in the model space.  Does anybody know why this occurs? Very simple code...
public static void ToggleColor(Document doc, System.Drawing.Color color)
            Category linecat = doc.Settings.Categories.get_Item(BuiltInCategory.OST_Lines);
            CategoryNameMap subcats = linecat.SubCategories;
            Category linetype = null;
            //Check if we already did this before
            foreach (Category line in subcats)
                if (line.Name == NPLUtil.LineType)
                    linetype = line;
            if (!(linetype == null))
                Transaction trans = new Transaction(doc, "ChangeColorLine");
                trans.Start();
                linetype.LineColor = ColorUtil.GetRevitColor(color);
                trans.Commit();
 Here's a gif after the transaction is complete.
jeremy_tammik
I cannot tell you why and I very much doubt it would help if I could.
However, this discussion might really help:
https://thebuildingcoder.typepad.com/blog/2014/06/refresh-element-graphics-display.html
normnoe
Ah I see. It's a hackier solution. I believe hiding and unhiding is more efficient than moving by minute values, due to the possibility of an element being linked or locked in the model.
                trans.Start();
                List<Element> detaillines = CollectDetailLines(doc, linetype);
                foreach (Element e in detaillines)
                    View ownedview = doc.GetElement(e.OwnerViewId) as View;
                    if (!e.IsHidden(ownedview))
                        ownedview.HideElements(new List<ElementId>() { e.Id });
                        ownedview.UnhideElements(new List<ElementId>() { e.Id });
                trans.Commit();
Thank you for the direction @jeremy_tammik.  We are up and running now!
