Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Dependance failed "PolyCurve.ByJoinedCurves" to rectify a non-closed boundary
3 REPLIES 3
l.virone
1837 Views, 3 Replies
Hello Everyone,
I'm trying to use methods used by some dynamo nodes in my revit IExternalCommand.
But unfortunatly i've encountered an error which I can't really identify :
Failed to load the file or the assembly "libG.ProtoInterface.dll" or one of its dependence
The PolyCurve object is inside ProtoGeometry.dll which is referenced in my visual studio project.
Here are all my dependencies :
I've tried to join the curves from an area to create a curveloop, in my implementation I decompose Revit elements in DesignScript elements to make the calculation and decompose it back to revit element.
Here is the method :
#region Namespaces
using System;
using System.Collections.Generic;
using System.Diagnostics;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.Exceptions;
using Autodesk.DesignScript.Geometry;
using Autodesk.DesignScript.Runtime;
using Autodesk.DesignScript.Interfaces;
#endregion
namespace sia
    public partial class geometry
        public class polycurve
            public static CurveLoop get_joined_loop(IList<IList<BoundarySegment>> sloops)
                CurveLoop final = null;
                List<Autodesk.DesignScript.Geometry.Curve> curves = new List<Autodesk.DesignScript.Geometry.Curve>();
                try
                    foreach (IList<BoundarySegment> sloop in sloops)
                        foreach (BoundarySegment s in sloop)
                            var c = s.GetCurve();
                            Autodesk.DesignScript.Geometry.Point p1 = Autodesk.DesignScript.Geometry.Point.ByCoordinates(c.GetEndPoint(0).X, c.GetEndPoint(0).Y, c.GetEndPoint(0).Z);
                            Autodesk.DesignScript.Geometry.Point p2 = Autodesk.DesignScript.Geometry.Point.ByCoordinates(c.GetEndPoint(1).X, c.GetEndPoint(1).Y, c.GetEndPoint(1).Z);
                            curves.Add(Autodesk.DesignScript.Geometry.Line.ByStartPointEndPoint(p1,p2));
                        break; //to avoid holes
                catch { }
                PolyCurve p = PolyCurve.ByJoinedCurves(curves, 0.1);
                Autodesk.DesignScript.Geometry.Curve[] joined_curves = p.Curves();
                try
                    foreach (Autodesk.DesignScript.Geometry.Curve curve in joined_curves)
                        double x1 = curve.StartPoint.X;
                        double y1 = curve.StartPoint.Y;
                        double z1 = curve.StartPoint.Z;
                        double x2 = curve.EndPoint.X;
                        double y2 = curve.EndPoint.Y;
                        double z2 = curve.EndPoint.Z;
                        XYZ pt1 = new XYZ(x1, y1, z1);
                        XYZ pt2 = new XYZ(x2, y2, z2);
                        Autodesk.Revit.DB.Curve new_curve = Autodesk.Revit.DB.Line.CreateBound(pt1, pt2);
                        final.Append(new_curve);
                catch { }
                return final;
Did anyone have a suggestion ?
Is it good to convert revit object to another one and to go back after the calculations or is it a simple way ?
My goal is to succeed in using the libraries in dynamo inside my IExternalCommands.
Tks,
Virone Lorenzo
Labels (1)
3 REPLIES 3
l.virone
in reply to: jeremy_tammik
Hi@jeremy_tammik and tks for your answer,
I found 2 answers which explain why designscript cannot work in an addin (outside dynamo) :
REVIT FORUM : https://forums.autodesk.com/t5/revit-api-forum/using-designscript-in-revit-addin/td-p/8203199
YOUR BLOG : https://thebuildingcoder.typepad.com/blog/2020/10/forge-design-automation-and-designscript.html
So, I will try a different approach using the API instead of trying to merge things which are not made to work together.
The link you gave reorganize the curves (and it's great) but doesn't join them to form a curveloop. Is it a way in the API to connect the curves together ? Maybe I need to find the intersection point of the curves projection to re-create them using this calculated point ?
My problem comes from the fact that area and room can work in revit while being slightly open. This helps the user but to perform operations I need to close this boundary.
Thanks again for your quick answer,
Virone Lorenzo
jeremy_tammik
in reply to: l.virone
I have definitely sorted such edges and joined them to form closed loops in the past, so one or two valid answer to your question ought to be found somewhere in the links I pointed out above.
To close the room boundary, you could ask it for its closed shell:
https://www.revitapidocs.com/2021.1/1a510aef-63f6-4d32-c0ff-a8071f5e23b8.htm
Jeremy Tammik, Developer Advocacy and Support, The Building Coder, Autodesk Developer Network, ADN Open
Autodesk Customer Advisory Groups
Rail Community
