Deleting Titleblocks
will.wydock
will.wydock
We often want to delete all titleblocks from sheets for various reasons. I am trying to create a routine that deletes titleblocks from the model. What I have put together seems to only work if the model only contains 1 family to delete otherwise the model just spins. Any idea what would be causing this?
		public void deleteTB()
			UIDocument uidoc = this.ActiveUIDocument;
			Document doc= uidoc.Document;
			bool deleteStartViewTB = true;
			int categoryid = (int)BuiltInCategory.OST_TitleBlocks;
			IEnumerable<Family> collector = new FilteredElementCollector(doc).OfClass(typeof(Family)).Cast<Family>().Where(q=>q.FamilyCategoryId.IntegerValue==categoryid);
			foreach (Family family in collector)
				using(Transaction T = new Transaction(doc, "Delete titlblock"))
					try
						T.Start();
						if(deleteStartViewTB)
							doc.Delete(family.Id);
						else
							if(!family.Name.StartsWith("Starting View"))
						T.Commit();
					catch (Exception ex)
						TaskDialog.Show("Error", ex.Message);
jeremytammik
You have wrapped each individual call to Delete an element one by one inside its own transaction, inside a loop over elements.
I would suggest restructuring that by first collecting all the elements you wish to delete, storing their element ids in a list, and then, right at the end, starting a transaction with one single call to Delete, passing in the entire list at once.
https://www.revitapidocs.com/2020/f4ce9113-b164-954e-5025-7b4edbdcc07d.htm
That will be cleaner and faster.
Jeremy Tammik
Developer Technical Services
The Building Coder
TripleM-Dev.net
The "spinning"/hanging of the model occurs because the collection is changed during the loop.
The deletion of the element causes the Collection to change, don't change a collection while going thruw it's collection, or convert it first.
(I actually expected a crash with this...)
In the Foreach loop collect all id's in one list, and use delete after the loop has ended!
As @jeremytammik also suggested.
I also see you actually delete the family from the Project, deleting the familyInstances not enough?
so-chong
In addition to Jeremy's and TripleM-Dev.net's replies, did you forgot to use the ToList() Method in your code?
And would this solve your problem?
	.Cast<Family>()
	.ToList();
