Delete entries in [Recent File List] in Revit.ini file
sofia_feist
sofia_feist
I have a plug-in that has to open a lot of revit files from a specific folder to execute some actions before closing them again, which is causing my Recent File List to become poluted with all the files that were opened.
Ideally, I would like to go through the Revit.ini file, navigate to the [Recent File List] and delete all the files opened from that specific folder (ResourcesFolder). Here 's a working script I did to modify the Recent File List in the Revit.ini file:
void ClearRecentFiles()
    string runningRevitVersion = thisControlApplication.ControlledApplication.VersionNumber;
    string iniFile = $"{Environment.GetEnvironmentVariable("appdata")}\\Autodesk\\Revit\\Autodesk Revit {runningRevitVersion}\\Revit.ini";
    string tempFilePath = Path.GetTempFileName();
    if (File.Exists(iniFile))
        using (var reader = new StreamReader(iniFile, Encoding.Unicode))
        using (var writer = new StreamWriter(tempFilePath, false, Encoding.Unicode))
            bool inRecentFileListSection = false;
            string inputLine = "";
            int fileIndex = 1;
            while ((inputLine = reader.ReadLine()) != null)
                if (inputLine.Trim().Equals("[Recent File List]", StringComparison.OrdinalIgnoreCase))
                    inRecentFileListSection = true;
                    writer.WriteLine(inputLine);
                    continue;
                if (inRecentFileListSection == true)
                    if (inputLine.StartsWith("[") && inputLine.EndsWith("]"))
                    else if (inputLine.Contains(ResourcesFolder))
                        continue;
                    else
                        var split = inputLine.Split(new char[] { '=' });
                        inputLine = $"File{fileIndex}={split[1]}";
                        fileIndex++;
        try
            File.Replace(tempFilePath, iniFile, null);
        catch (Exception e)
            Console.WriteLine(e.Message);
However, it's come to my understanding that the Revit.ini file is only written/overwritten after OnShutdown() method is run and that I actually need to close Revit before modifying the Revit.ini for this to work.
I could maybe create a standalone application that is triggered each time revit is closed to clear the Recent files list but is that approach really the only/best approach? This would also not solve the problem that if I close all my tabs (Documents) in Revit without closing Revit, I would still get the poluted Recent Files list because the script is only run after Revit is closed.
Any suggestions?
Best Regards,
Sofia
jeremy_tammik
Yes, I have a suggestion. Hopefully, it avoids all your problems in a simple way. My suggestion is:
  • Do not write anything to Revit.ini at all
  • Before opening any of the polluting files, read the recent file list from Revit.ini and store it in a variable A
  • After opening the files and thus polluting it, open (and close) all of the files in A again
Wouldn't that solve your problem in a simple manner?
sofia_feist
It is a viable suggestion but I wanted to avoid even more waiting time of an already lengthy operation, especially when my Recent File List has 28 files to open and close in it.
jeremy_tammik
My assumption was that the process opening and closing such a large number is set up to run unattended, with nobody sitting and waiting for it to end. Good luck finding an optimal solution! Please let us know what that is for you. Thank you!
