Define a CylindricalSurface
a.sabatier
a.sabatier
Hi
I have a silly question : how do you define a cylindricalSurface?
I've tried this , but doesn't work:
XYZ pointInsersion;
Frame framecylindre = new Frame(pointInsersion, new XYZ(1, 0, 0), new XYZ(0, 1, 0), new XYZ(0, 0, 1));
CylindricalSurface cylindreGrue = new CylindricalSurface(framecylindre,50);
Thanks for your help!
Alex
jeremytammik
Why do you call the constructor?
Does the class even expose a constructor?
I do not see it in the documentation.
Have you looked at the documentation?
https://apidocs.co/apps/revit/2019/6d3492bd-3205-d936-5672-9f8be4ee97c1.htm
All I see is the `Create` method to construct a cylindrical surface defined by a local coordinate system and a radius:
https://apidocs.co/apps/revit/2019/ae360b1d-65c3-2991-62c7-13193f5792e5.htm
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
a.sabatier
Hi
Thanks. I didn't see it.
I've another question.
I'm trying to get the intersection (bool) beetween the cylindricalSurface I created and a solid.
I thought I could create a Cylindrical Surface and then intersect it with my solid but don't really know how to do it..
jeremytammik
I cannot really believe that you seriously are interested in the intersection between a surface and a solid.
Do you in fact really want the intersection between a cylindrical solid and another solid?
If so, it makes no sense to create a surface.
If you wish to create a solid cylinder, you should take a look at the methods provided by the GeometryCreationUtilities class:
https://apidocs.co/apps/revit/2019/28337984-cc15-72d7-f305-fafcac75d695.htm
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
a.sabatier
Hi
Thanks for your help.
I am interested in the intersection between my cylindrical surface and a solid.
I will do it with a solid if it's not possible but I'll have to write 3 cases if the intersection is the entire solid // a part of the solid // empty.
Thanks.
Alex
jeremytammik
When you say, 'intersection between my cylindrical surface and a solid', what kind of result are you expecting?
It would be a pretty weird partial surface, wouldn't it?
You would need some pretty high-level free-form geometrical algorithms to handle and process that result, wouldn't you?
The Revit API does not offer tools at that level of complexity.
I think that the simplified approach that you mention as an alternative sounds much more doable.
Good luck, and looking forward to hearing how you end up solving this!
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
a.sabatier
Hi
I wanted a bool result like true if there is an intersection and false if
the intersection is empty.
But I did it the way you advised me and it works perfectly.
Thanks for your answers!
Cheers
Alex
