Default Leader Length
is it possible to set the Default leader Length via API. I need to set the Independent Tag Leader Length programmatically. Please help
jeremytammik
Please refer to the documentation on the IndependentTag class members:
https://www.revitapidocs.com/2020/599b2ef1-24b8-fef5-adf2-befffbd2af48.htm
I see write access to the LeaderElbow and LeaderEnd properties, so you can control the position of the elbow and end of the tag leader.
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks Jeremy for your response.
I was using leaderend and tagheadposition to get the leader length and adjust it as per user input by converting to internal units.
Was checking out for a more straight forward method by setting "Default leader length" property which I guess is not available.
Thank you
Rahul
floretti
Still not available? It would be handy to have that field accessible in the API.
