Debug freeze with TextBox.EnterPressed Event.
RPTHOMAS108
Mentor Mentor
RPTHOMAS108
Hello All
What I am finding is that when I put a break point within the code that handles TextBox.EnterPressed event that the Debug session freezes and eventually arrives at the below message.
I would like to know what is causing this and if it is just something I am experiencing or is a general more widespread problem. This is a case of something that works as long as you don't debug it. The help link on the message box suggests certain things I've tried but I don't get this problem except for the handling of this specific event (so what is special about it)?
The project files are attached.
jeremytammik
To mitigate this and numerous other problems, I would recommend avoiding all kind of user interaction in connection with debugging anything at all unless it is completely trivial. A Windows message box and a Revit TaskDialog have complex interactions with messages and threading and stuff. Whenever I run into a problem with such an interaction, I switch to logging the required debugging information to the Visual Studio debug window (only a little better) or to a completely separate text file (much better).
Sorry if that does not address your question at all!
Jeremy Tammik
Developer Technical Services
The Building Coder
RPTHOMAS108
Hello Jeremy
Originally I didn't have the TaskDialog but I experienced the same issue. It's not a major problem for me I was just wondering if it was just me getting the issue or is a common problem with this event. Also if there was a better way of subscribing to it?
Regards
Richard
