DB LINK and Shared Parameters
arwarnock
arwarnock
I am just getting into using Revit and Revit DB Link. Whenever I export to my database, project parameters come over, but shared parameters do not. Is there anyway get the shared parameters into my database?
jeremy_tammik
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, if you are not programming anything yourself using the Revit API, this is not the optimal place for this question.
You might have better luck in one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
