I made a DataSet, and bounded (DataSource/BindningSource) it to a DataGridView.
From here the user can type in (double) values which I can later use for my calculations.
I've added a button for saving and loading the tables. When i Load/Opens a table the values are displaying in the DataGridView, but I don't manage to connect/set it to the DataSet.
I've tried to Add, clone, New Object and loop through to set det values, but probably with some errors.
Below is the main load/open code. Here without the Dataset; data_vault.Revenue.
StreamReader read_table = new StreamReader(File.OpenRead(open_data.FileName));
DataTable dtable = new DataTable();
dtable.Columns.Add(new DataColumn("L2_n", typeof(double)));
dtable.Columns.Add(new DataColumn("L1_n", typeof(double)));
//Splitting the textfile
List<string> s_list = new List<string>();
string str = read_table.ReadLine();
char[] spearator = { '.', ' ' };
String[] strlist = str.Split(spearator);
foreach(String s in strlist)
s_list.Add(s);
int count = s_list.Count;
int i = 0;
//Inserting values in the table
for(int j = 0; j < (count-1)/2;j++)
DataRow RowValues = dtable.NewRow();
RowValues[0] = Convert.ToDouble(s_list[i]);
i++;
RowValues[1] = Convert.ToDouble(s_list[i]);
i++;
dtable.Rows.Add(RowValues);
dataGridView1.DataSource = dtable;
Later I'm collecting the values;
foreach (var obj in data_vault.Revenue)
double l2_tall = (Double)dataGridView1["l2nDataGridViewTextBoxColumn", i].Value;
l2_test.Add(l2_tall);
double l1_tall = (Double)dataGridView1["l1nDataGridViewTextBoxColumn", i].Value;
l1_test.Add(l1_tall);
i++;
