DataStorage does not get stored in document
christostsar
christostsar
I've read the information and followed the instructions in https://thebuildingcoder.typepad.com/blog/2012/05/devblog-devcamp-element-and-project-wide-data.html... to create a DataStorage with project-wide settings. The problem is, after the call to DataStorage.Create(), I do get a new data storage object with an ElementId, but then this element does not exist in the document when I try to retrieve it or snoop it.
Here I make the transaction:
RevitProjectExportSettings exportProjectSettings = new RevitProjectExportSettings(exportOptions);
RevitProjectDataStorage dataStorage = new RevitProjectDataStorage();
using (Transaction t = new Transaction(doc, "Write project settings"))
   t.Start();
   dataStorage.writeProjectSettings(doc, exportProjectSettings);
   t.Commit();
 Here is writeProjectSettings() routine:
public void writeProjectSettings(Document doc, RevitProjectExportSettings settings)
	var settingDataStorage = getSettingsDataStorage(doc);
	if (settingDataStorage is null)
		// Here I do get a new DataStorage element with a proper ElementId,
		// but when I snoop the database later it does not exist.
		settingDataStorage = DataStorage.Create(doc);
	Entity settingsEntity = new Entity(RevitProjectExportSettingsSchema.getSchema());
	// Save all settings to the entity.
	settingsEntity.Set(RevitProjectExportSettingsSchema.EXPORT_FILE_NAME, settings.ExportFileName);
	settingsEntity.Set(RevitProjectExportSettingsSchema.EXPORT_FILE_PATH, settings.ExportPath);
	settingsEntity.Set(RevitProjectExportSettingsSchema.EXPORT_MODE, settings.ExportMode);
	settingsEntity.Set(RevitProjectExportSettingsSchema.EXPORT_UNIT_SET, settings.UnitSet);
	// Identify settings data storage.
	Entity idEntity = new Entity(DataStorageUniqueIdSchema.getSchema());
	idEntity.Set("Id", dataStorageId);
	settingDataStorage.SetEntity(idEntity);
	settingDataStorage.SetEntity(settingsEntity);
Here is the getSettingsDataStorage() routine:
private DataStorage getSettingsDataStorage(Document doc)
	FilteredElementCollector collector = new FilteredElementCollector(doc);
	var dataStorages = collector.OfClass(typeof(DataStorage));
	// Find our data storage identified by containing our specific settings schema.
	foreach (DataStorage dataStorage in dataStorages)
		Entity settingIdEntity = dataStorage.GetEntity(DataStorageUniqueIdSchema.getSchema());
		if (!settingIdEntity.IsValid()) continue;
		// Check that the id matches our storage id.
		var id = settingIdEntity.Get<Guid>("Id");
		if (id.Equals(dataStorageId))
			return dataStorage;
	return null;
RPTHOMAS108
Have you stepped through the code all the way to t.commit?
What API interface are you calling this from, are you returning Result.Succeeded?
The example is quite old there is now the ..DB.ExtensibleStorage.ExtensibleStorageFilter which will allow you to filter for elements containing your schema id such as the DataStorage you are trying to find.
renencon
I suppose when say you want to create project-wide settings you refer to a single location within the document to store your exportProjectSettings.
Also, in your writeProjectSettings routine the fields in your schema if they are strings and named as listed below
EXPORT_FILE_NAME
EXPORT_FILE_PATH
EXPORT_MODE
EXPORT_UNIT_SET
and they should have been created in your schema creation/lookup routing as bellow
SchemaBuilder schemaBuilder = new SchemaBuilder(<<YOUR-SCHEMA-GUID here>>);
schemaBuilder.AddSimpleField("EXPORT_FILE_NAME", typeof(string));
then replace the lines below
with
settingsEntity.Set<string>(“EXPORT_FILE_NAME”, settings.ExportFileName);
settingsEntity.Set<string>(“EXPORT_FILE_PATH”, settings.ExportPath);
settingsEntity.Set<string>(“EXPORT_MODE”, settings.ExportMode);
settingsEntity.Set<string>(“EXPORT_UNIT_SET”, settings.UnitSet);
I do not think the DataStorageUniqueIdSchema entity is required here, and the lines below can be removed.
Now, your getSettingsDataStorage routine I would suggest something like the one below
Guid RevitProjectExportSettingsSchemaGuid = RevitProjectExportSettingsSchema.getSchema().GUID;
ElementFilter ElementFilter =
new LogicalAndFilter(
new ExtensibleStorageFilter(RevitProjectExportSettingsSchemaGuid),
new ElementClassFilter(typeof(DataStorage)));
var dataStorages = collector.OfClass(typeof(DataStorage)).WherePasses(ElementFilter);
if (dataStorages.FirstOrDefault() is DataStorage dataStorage && dataStorage.IsValidObject)
return dataStorage;
return null;
I hope the above makes sense.
christostsar
The problem was the Result.Succeeded as suggested. I did not know that the returned result had any impact on the transactions if they were committed.
Thanks a lot for the info on the new filters, I am definitely going to incorporate those.
