data type handling from Revit 2022 to 2023
jagadeesh116
jagadeesh116
def PBE(_Doc, _PN, _PT):
    _Bindg = _Doc.ParameterBindings
    _i = _Bindg.ForwardIterator()
    _i.Reset()
    while _i.MoveNext():
        if _i.Key != None and _i.Key.Name == _PN and _i.Key.GetDataType == _PT:
           return True
    return False
_PN = "Sampel"
_PT = ForgeTypeId.GetType(SpecTypeId.String.Text)
OUT = PBE(_Doc, _PN, _PT)
Revit 2022:
_Txt = System.Enum.GetValues(ParameterType)[1]
_Area = System.Enum.GetValues(ParameterType)[5]
_Nmbr = System.Enum.GetValues(ParameterType)[3]
_Bool = System.Enum.GetValues(ParameterType)[10]
_Int = System.Enum.GetValues(ParameterType)[2]
_Lngth = System.Enum.GetValues(ParameterType)[4]
Revit 2023:
_Txt = ForgeTypeId.GetType(SpecTypeId.String.Text)
_Area = ForgeTypeId.GetType(SpecTypeId.Area)
_Nmbr = ForgeTypeId.GetType(SpecTypeId.Number)
_Bool = ForgeTypeId.GetType(SpecTypeId.Boolean.YesNo)
_Int = ForgeTypeId.GetType(SpecTypeId.Int.Integer)
_Lngth = ForgeTypeId.GetType(SpecTypeId.Length)
 How can I update the data type handling in my PBE method from Revit 2022 to Revit 2023
Thanks in advance
RPTHOMAS108
ForgeTypeId implements equality function and each class property of the SpecTypeId class  returns a ForgeTypeId therefore isn't it just:
_PT = SpecTypeId.String.Text
etc.
Not sure why you was returning all the values from an enum just to pick just one of them in the first place i.e. you could have just used the integer representation in your pre ForgeTypeId code.
nice3point
You can use reflection in C# to get all values
var searchFlags = BindingFlags.Static | BindingFlags.Public | BindingFlags.DeclaredOnly;
var dataTypes = new List<PropertyInfo>();
dataTypes.AddRange(typeof(SpecTypeId).GetProperties(searchFlags));
dataTypes.AddRange(typeof(SpecTypeId.Boolean).GetProperties(searchFlags));
dataTypes.AddRange(typeof(SpecTypeId.String).GetProperties(searchFlags));
dataTypes.AddRange(typeof(SpecTypeId.Int).GetProperties(searchFlags));
dataTypes.AddRange(typeof(SpecTypeId.Reference).GetProperties(searchFlags));
foreach (var type in dataTypes)
    var dataType = (ForgeTypeId)type.GetValue(null);
Jagadeesh_reddi
Observer
Observer
_i.Key.GetDataType() works for "data type of a parameter" in revit 2023
