cut solid with a solid
pnoZFP35
pnoZFP35
I create solids with this line of code until I have the solids I need
Solid SolidInstance = GeometryCreationUtilities.CreateLoftGeometry(CurveLoop, solidOptions);
and when I have the solids I want to take the first solid and use the rest of the solids to cut the first solid so I can get a solid that look like this
but I cant find what I need to cut the Solids, what have I missed how can I cut solids?
RPTHOMAS108
BooleanOperationsUtils.ExecuteBooleanOperation
BooleanOperationsType.Difference
Sometimes these things are a bit hit and miss though depending on tolerances.
pnoZFP35
thanks for the help it worked, must have missed it. didn't know the BooleanOperationsType.Difference was for cutting solid
RPTHOMAS108
Yes it is a bit of a strange one in a sense.
Ordinarily 'difference' would be the parts from two solids that don't intersect (the opposite of 'intersect'). However, I believe that the logic is that since you are changing just one of the input solids you only get the difference volume of that solid. Otherwise, you would end up with two volumes joined together by edges alone. It is actually quite common in a lot of modelling programs for 'difference' to be thought of as cut.
In AutoCAD they have 'subtract' which is more obvious terminology perhaps.
rhanzlick
We struggled before gaining this understanding as well, but in my experience, it works exactly as you've described.
