Curve Offset
Curve Offset
Curve Offset
Hello everyone!
How can I use offset a curve (Nurbspline) in revit api C#?
I thought that the 'Curve.CreateOffset Method' contains something to do it but it seems that it doesn't...
Thank you
jeremytammik
Dear Anarchyfree,
Why do you say that Curve.CreateOffset does not offset a nurb spline?
The remarks on that method in the Revit API help file state something different:
Remarks ... Note that for elliptical fragments and NurbSpline curves, the offset will be created as a HermiteSpline...
From my understanding of that statement, nurb splines are indeed offset, and the result is a hermite spline.
If you need your result to be a nurb spline, you will iether have to implement the whole offset method yourself or convert the resulting hermite spline back to a nurb spline.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
