Curve-based family instance created in wrong location
boostyourbim
boostyourbim
Hi
I'm trying to place a line-based family on an edge of a roof. The API creates the instance but not in the location specified by the diagonal edge that was selected. Any ideas?
        public void voidCut()
            Document doc = this.Document;
            UIDocument uidoc = new UIDocument(doc);
            FamilySymbol voidSym = new FilteredElementCollector(doc).OfClass(typeof(FamilySymbol)).Cast<FamilySymbol>().FirstOrDefault(q => q.Family.Name.Contains("BoxGutterVoidSweep"));
            Reference edgeRef = uidoc.Selection.PickObject(ObjectType.Edge);
            RoofBase roof = doc.GetElement(edgeRef) as RoofBase;
            Edge edge = roof.GetGeometryObjectFromReference(edgeRef) as Edge;
            Curve curve = edge.AsCurve();
            using (Transaction t = new Transaction(doc, "void"))
                t.Start();
                FamilyInstance voidInstance = doc.Create.NewFamilyInstance(curve, voidSym, null, StructuralType.NonStructural);
                doc.Regenerate();
                LocationCurve lc = voidInstance.Location as LocationCurve;
                lc.Curve = curve;
                t.Commit();
Mustafa.Salaheldin
Please try the following code (Revit 2016 API) and tell me it works
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS2
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                FamilySymbol famSym = new FilteredElementCollector(CachedDoc).OfClass(typeof(FamilySymbol)).Cast<FamilySymbol>().FirstOrDefault(q => q.Family.Name.Contains("BoxGutterVoidSweep"));
                Reference edgeRef = CachedUiApp.ActiveUIDocument.Selection.PickObject(ObjectType.Edge);
                RoofBase roof = CachedDoc.GetElement(edgeRef) as RoofBase;
                Options geoOptions = CachedDoc.Application.Create.NewGeometryOptions();
                geoOptions.DetailLevel = ViewDetailLevel.Fine;
                geoOptions.ComputeReferences = true;
                GeometryElement geoElem = roof.get_Geometry(geoOptions);
                Face face = null;
                foreach(GeometryObject geomobj in geoElem)
                    Solid s = geomobj as Solid;
                    foreach(Face f in s.Faces)
                        foreach(EdgeArray ea in f.EdgeLoops)
                            if(ea.Cast<Edge>().ToList().Contains(edge))
                                face = f;
                                break;
                Line line = edge.AsCurveFollowingFace(face)as Line;
                using (Transaction t = new Transaction(CachedDoc, "void"))
                    t.Start();
                    famSym.Activate();
                    FamilyInstance voidInstance = CachedDoc.Create.NewFamilyInstance(face, line , famSym);
                    t.Commit();
                return Result.Succeeded;
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
        #endregion
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
